I'm using Jean's excellent peak & hold board. With MS3, do need to take the injector outputs from the header that normally goed to the MS3 expander board, or can I use the exisitng wiring? I'm currently on 2.1 MS2ex code with no cam input, so there are only two outputs feeding the peak & hold board. I'm just trying to find the neatest soultion while waiting for the expander board to come out.
I also guess i'm going to have to build a an additional VR conditioner for the cam input as that's on the expander board also?
Rick
Injector Outputs
Re: Injector Outputs
That's a good question. I'm running sequential with the P&H board now, and I'd definitely like to stick with the P&H board as it has better injector drivers than the MS3x board will (not saying they aren't good enough, just not as good as). I've been hoping someone would post a wiring how-to to hook that P&H board to the MS3 sequential outputs. I'll never go back to batch fire.
Brian
'84 Dodge Rampage
'84 Dodge Rampage
Take a look at the end of http://www.ms3efi.com/doc/hardware.html for the layout of the two pin headers.
I am pretty sure what James is saying is that you need to use the J1 pins on the page referenced to trigger the P&H board. I am using these pins to trigger my external HiZ injector driver board in sequential mode and have been since I installed the MS3.
KeithG
KeithG
