MS3 - progress monitor
How are you getting on with MS3 ?
Waiting for it to arrive
20
3%
Received it ok, not done anything yet
27
4%
Waiting on other parts
18
3%
Stuck - problems
59
9%
Bench testing only so far
62
10%
Partway through on-engine installation
52
8%
Engine up and running, but not finished
203
32%
All running, does what I want - success!
196
31%
Total votes : 637
Re: MS3 - progress monitor
Postby mr_minnis » Wed Jun 26, 2013 11:42 am
my car starts and runs ok. Getting things buttoned up with ve analize was pretty easy. I am having trouble getting dual fuel table with seq injection to work. fuel table 3 doesn't do anything, even if i change the ve values to 100. I am doing some research and such to make sure i don't have a setting wrong.
88 Stang LX Vert. 3.73s and MS3x, D585 Coils AEM EPM
mr_minnis
Postby 408Coupe » Wed Jul 10, 2013 12:20 am
Have my 91 Mustang up and running. Fired it up today after finally fixing some trigger wheel problems, got the idle all dialed in and then the wideband decided to stop working. Will be looking in to the problem in the morning and taking the car out for some road tuning.
1991 Ford Mustang
Running ms3x with full sequential fuel and spark using GM truck coils.
408Coupe
Postby gboezio » Tue Jul 23, 2013 7:51 pm
1984 Jeep CJ-7,
Engine : 2007 6.0L LY6 with L92 heads, Howard 219/230 112 LSA cam, stiffer springs from howard, VVT deleted (1X cam wheel)
Tranny : 4L80E adapted to a DANA300 Transfer case using cable encoder for VSS
ECU : MS3X + LC1 (left bank) fully sequential, 2xfan control, alternator control, exhaust cutout control, sidepipes flame thrower control
TCU : GPIO Megashift trough CAN Bus, TPS gear table, MAP pressure control
Fully running and very fun to drive, I have built the whole harness, a box big enough to put MS3 and GPIO, 8 relays, 3x8 fuse holders, switches and a whole bunch of wires.
gboezio
Postby allisonenginecar » Mon Jul 29, 2013 6:50 am
up and running but working on tune Here are some vids http://youtu.be/csxLar1pIA4 http://youtu.be/L8JdhX8WHG8
http://youtu.be/cGMIbDZIKho
allisonenginecar
Postby ShelbyZ24 » Fri Aug 09, 2013 7:42 pm
Up and running and running well. 24 turbo rwd Shelby Z 10.19@130 at 33 psi boost
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
ShelbyZ24
Postby GDP » Wed Aug 28, 2013 8:30 pm
Up and running in about a two weeks worth of work in a small block chevy 350 with a turbo, I have to say this thing is awesome, think I'll be doing one in my trans am now.
GDP
Postby mobythevan » Fri Dec 13, 2013 2:50 pm
Finished upgrading my LM7 5.3 RX7 from MS1 to MS3. Running very well. Idles and cruises great with 80lb injectors. The only thing I have not finished is turning on the IAC.
86 RX7 Turbo 5.3 MS3
mobythevan
Postby Chiburbian » Tue Dec 17, 2013 11:07 am
Selected "up and running but not finished" because there are still things I need to work out, but for all intents and purposes I am done. I don't like my idle tune, I don't like me EBC, I need to tweak my VSS settings to give me closer speed vs actual, and I really should do a good spark tune once the above is done.
Once I get my idle and boost figured out I will switch my "vote" but I don't think I will ever be completely done. I will just keep adding features and refining stuff. For example, I want to add a flexfuel sensor and do blended maps, but that only makes sense after I build the engine which is a year or two out.
Chiburbian
Postby Bzevey » Mon Dec 23, 2013 5:51 am
Its up and running for the most part have a misfire around 1900rpm and looking to expand to the ms3x board
Bzevey
Postby sedd » Tue Feb 25, 2014 7:09 pm
mine is a continuous work in progress, up and running but never finished is my vote. I am really enjoying the product and this forum. this forum is quite helpful and I continue to learn and then learn again about what I thought I knew.
1970 Chevelle, 540 big block, AFR heads, headers, mild cam
MS3 release 1.4.0, sequential fuel, LS2 coil per plug
Tuner Studio MS V3.0.05
sedd
Postby Yetidragon » Thu Apr 03, 2014 3:12 pm
Running 261 bhp on my mk1 mx5 with cops and boost control.... Very happy bunny
Next I'm gonna try the real time clock and the knock detection.
Yetidragon
Postby Barton » Thu Apr 03, 2014 5:23 pm
Ms3 is the most complete EMS on the marked, I have sucessfull installed several of them on different engines, using a lot of features!
Megasquirted engines: 4g63, k24a2, b16-b18, duratec, ecotec, fiat 8v-16v, modular 4.6 32v, 1fz-fe, fiat 5cil 20v, Opel corsa, G54B, VW AG, 2ZZ-GE.
https://www.facebook.com/Bartonefi
instagram: @bartonefi
Barton
Postby Matt Cramer » Fri Apr 04, 2014 5:43 am
Another MS3 project:
A 2007 Chevy 4.8 in a '72 Chevy pickup, running MS3-Pro. Haven't been able to complete dynoing it due to transmission slip issues.
Postby pyrosanltd » Fri Apr 04, 2014 9:35 am
Volvo 242
b21FT bored and stroked to 2.4 liters
Mitsubishi 4g63 rods
offset ground crank
Weisco pistons
Stage1 turbo cam soon to be stage3
15G turbo soon to be TD05HR16G (once header is built)
Bar plate intercooler
Full Sequential !
ImageThe car runs! makes boost, and is a joy to drive :yeah!: Now I just need to work on the gas mileage and some rough spots in the tune.
Major overhaul on tune and calibration car is averaging 25 miles per gallon. Currently in process of finalizing header for new turbo, and getting the goods together to build a proper engine harness.
pyrosanltd
Postby omniserv2 » Sun May 11, 2014 9:23 pm
I'm finally done with my 1983 280zx NA fuel only install. The engine runs better now than it ever has. I even installed bigger fuel injectors and tuner studio was able to adjust the fuel mixture, now the engine runs so smooth at times we can't tell it's running. The car only has 64K miles on it and the engine is so quiet when it's running you can here the fuel injectors clicking. Getting rid of the clutch fan has a lot to do with it too.
There will be other things I'll want to do, like add GPS or a VSS. Maybe a tablet on the dash so I can monitor the MS3 at all times without my laptop.
Here's the changes from a stock 280zx we made.
MS3
320CC injectors
custom fuel rail
fuel pressure gauge
adjustable fuel pressure regulator
60MM throttle body from a Infinity Q20
Electric radiator fan, also from the Q20
Custom intake filter
Removed all old emissions stuff
Now it's on to our 1987 300zx turbo. We have began building the MS3 for it also. That one will be ignition and fuel + turbo control.
omniserv2
Postby volospian » Tue Jul 08, 2014 5:45 am
Mine is now in the "starting and idling" realm :yeah!:
Running MS3 with MS3X, in fully sequential, COP mode on an L33 5.3 HO with LS6 intake and injectors and a Getrag 265 5 speed manual 'box. The whole lot is in an AK Sportscars CObra replica Kit.
Starts, idles. Now I need to finish the accessories (knock conditioner, finish the wideband lambda wiring, and double check everything... but I think I'll worry about finishing the car build before I think about tuning. For now, I just need to make sure the clutch is working as expected (or should I say "working correctly" as I expect it will be wrong somehow :)).
Rich.
volospian
Postby 02plus » Wed Jul 09, 2014 12:11 pm
Whe have two running , BMW 2002 M42 ITB,Peugeot 205 (105 gti engine) en and one project BMW .
The BMW has run with M10 engine ITB seq.Running ok still tuning.
Bmw M535 lpg
Bmw 2002
VW bus 2.2 subaru
MS2extra
02plus
Postby ShelbyZ24 » Tue Jul 15, 2014 3:28 pm
87 Daytona Shelby 2.4 turbo. Std bore 8.8-1 pistons 33 psi boost. 904 trans 4.56 Chrysler 8.75" diff. Holset Hx40 turbo, home made header, 96 lb injectors running ms3x crank sensor only. best et so far 9.86 best 60 ft 1.28 best mph 135.15 dyno'd at 386 hp at the rear wheels
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
ShelbyZ24
Postby piledriver » Tue Jul 15, 2014 6:58 pm
Yikes, for a moment there I thought you had it towing the camper :lol:
Awesome!
piledriver
Postby thokes82 » Thu Jul 31, 2014 7:28 am
We where on track (Lausitzring, Germany) with my M3 S50 EURO with ITB Mode, CAN Display (Race Technology Dash2) and Alpha 1.4 Code...
:yeah!:
Race car building documentation: www.kessel.tk (nice pics but only german laguage so far...)
thokes82
PreviousNext
Return to MS3 General Support
Users browsing this forum: drewhastheinternet and 2 guests
