Ignition settings for LS2 (truck) coils
Just curious.... what kind of ignition settingss are being used for LS2 coils. My settings seem to work ok but I was just wondering what other people are using.
Mine are as follows: Use table
First Deriv Prediction
Cranking Dwell 6.0 ms
Cranking Advance 10 deg
Standard Dwell
Max Dwell 2.8 ms
Min Dwell 1.0 ms
no latency
no overdwell
no underdwell
no spark trim
Jeff
Standard Dwell
Max Dwell 2.8 ms
Min Dwell 1.0 ms
no latency
no overdwell
no underdwell
no spark trim
Jeff
Support the developers!
Re: Ignition settings for LS2 (truck) coils
Jeff-
That seems like super short dwell at 2.8ms max? Doesn't the write up Bruce did call for 5.5ms?
I'll take a look and see what I'm running. On my BMW, I have put about 6,000 miles on them already (which is a lot for this non-daily car) and it works great
Also, maybe someone else can say for sure, but I think they have internal limiters and protection? So you can let the shaft out a little bit from the MS.
Scott.
Scott.
__________________________
MSIIIx V3.0 Big Poncho - Sequential fuel and ignition
Sequencer running an '80 635csi Euro M90 - Sequential fuel and ignition
I'm running LS2 coils on my MSII 383 stroker. I use 5ms of dwell and they run great.
1979 Camaro
383 stroker w/Ramjet EFI manifold
MS2 Extra running semi-sequential, wasted spark
i run 5.5ms in both applications, with voltage compensation described here: http://www.megamanual.com/seq/coils.htm
work great for me
work great for me
Awsome thanks very much. ( I forgot about that page!)
I did, twice.... and ran a search on the forums for LS2 coil threads and read all of them. I can never find the link to that page. I'm going to bookmark it right now.
Jeff
Jeff
Which particulat part of that page needs including in the MS3 manuals?
The info concerning dwell times and the connector views would be really nice. I suspect that most MSers don't have access to the service information I do as an Auto tech by trade.
I can get factory schematics for most cars built in the last 30 + years
Thank you James!
Thank you James!
The connector information is there already though? http://www.msextra.com/doc/ms3/ignition.html#coils and scroll down a little.
I'll get the dwell number added.
So they are.... I guess I need to look at the Docs on a daily basis to see what's new.....jsmcortina wrote:The connector information is there already though? http://www.msextra.com/doc/ms3/ignition.html#coils and scroll down a little.
Those have been there for a few months at least.prof315 wrote:So they are.... I guess I need to look at the Docs on a daily basis to see what's new.....jsmcortina wrote:The connector information is there already though? http://www.msextra.com/doc/ms3/ignition.html#coils and scroll down a little.
I just bought a set of LS2 (non-truck version) for the sequencer - $12.00 each
I'll watch this thread.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
These are truck coils we are using. It's a boosted motor, about 15psi and 9.5 to 1 static compression. Not even a suggestion of ignition problems. Timing is dead on and the wiring instructions are spot on perfect.
Where did you find LS2 coils for $12 ?
http://www.msextra.com/forums/viewtopic ... 2&p=243194preston wrote:Where did you find LS2 coils for $12 ?
Peter Florance
PF Tuning
PF Tuning
I got mine at the local u-pick junkyard. $30 for 4 with the bracket and sub harness. BTW I'm a former GM dealership tech and I have only heard of ONE instance of failure with these coils. The guy who services our lifts has a 10 year old 1500 silverado with 325,000 miles on it. He has replaced ONE coil.
I never see them at our yard. I'd rather have the truck units as they mount better for me.prof315 wrote:I got mine at the local u-pick junkyard. $30 for 4 with the bracket and sub harness. BTW I'm a former GM dealership tech and I have only heard of ONE instance of failure with these coils. The guy who services our lifts has a 10 year old 1500 silverado with 325,000 miles on it. He has replaced ONE coil.
But 80 shipped for 6 was easy button for me.
I got the shells pins and seals at Mouser.
Peter Florance
PF Tuning
PF Tuning
one of my local junkyards sells the complete 4.8 with truck coils for $150 lol
I figure if my engine blows, I pick up another 4.8 for $150, sell the coils for $60, the oil pan for $50 and the intake intake and throttlebody for $20 and the engine was almost free.
nice to live in truck country
picked up a set of D581 coils, spark leads, and wire harnesses for $107 today! go pull-a-part!CyanJaguar wrote:one of my local junkyards sells the complete 4.8 with truck coils for $150 lol
