Button / light Wiring and usage
Within "insertion" mode you do not need the button. It is required for "button" mode to start and stop datalogs.
The LED/light output is optional in either mode but can be helpful to more quickly diagnose any error conditions and confirm that logging is happening. It is recommended when using button mode. When using the MS3X spark outputs, it is likely convenient to set the "middle LED" as the LED output as zero wiring is required.
SD Card logging
SD Card logging
In the drawing that follows this statement in SD Datalogging in the MS-3 section of the Manual, what do "To Switch Input" in the left diagram and "To Output" in the right diagram mean?
Brian
MS3-3X v1.3.0; TS Ultra 3.0.28; 911SC 3.0L; 3.2 intake; 2 Spartan O2 sensors; LS-2 coils; 60-2 geartooth and hall; dizzy hall
Re: SD Card logging
When you configure SD logging in TunerStudio, you must pick an input wire for the pushbutton. There is a dedicated datalog wire on the MS3X card which most people use for this purpose. The output is optional, but it's the same thing - you pick an output wire for the indicator light.cmonref wrote:In the drawing that follows this statement in SD Datalogging in the MS-3 section of the Manual, what do "To Switch Input" in the left diagram and "To Output" in the right diagram mean?
1992 Volvo 740 Wagon - Beater Car...CAI, 16T, catback, MS3/MS3X, & HID's
1996 Eagle Talon TSi AWD - Daily Driver...RAI, Big 16g, 3" TBE, HID's, etc.
Re: SD Card logging
VolvoGuy50,
Thanks for your answer, but it leaves the question begging in my MS-neophyte mind.
For the "to output" wire on the right diagram, "you pick an output wire for the indicator light" doesn't tell me how to CHOOSE the output wire. Obviously a ground is needed, but just any old ground will result in the light being ON when the MS is on. Maybe the "to output" is really the "D/log in (gnd)" wire, which -- I'm guessin' here -- becomes a ground when the SD card is datalogging?
Brian
The "dedicated datalog wire on the MS3X card" is labeled "D/log In (gnd)" which puts looks like it puts a ground wire on BOTH sides of the switch in the left diagram. That's not going to do much ...When you configure SD logging in TunerStudio, you must pick an input wire for the pushbutton. There is a dedicated datalog wire on the MS3X card which most people use for this purpose. The output is optional, but it's the same thing - you pick an output wire for the indicator light.
Brian
Brian
Re: SD Card logging
use one of the LED outputs on the mainboard (The ones normally used for WUE or spark outputs).
Re: SD Card logging
OK, maybe I undestand which wires to use:
For the "switch input": MS3X pin 30 for Datalog in (active ground).
For the LED "output": MS3 pin TBD to use D15 for Datalog LED
Now to figure out how to use the two sources and bring D15 out to a pinout.
Thanks!
Brian
Thanks!
Brian
Brian
Re: SD Card logging
That's just over complicating things. If you use the mainboard LED, just look at it where it is.
Otherwise pick one of the other output choices in the dropdown - such as one of the MS3X mid-current outputs and connect a 12V LED or small bulb to it as shown in the diagram on the manual page.
Re: SD Card logging
See these diagrams:
http://www.msextra.com/doc/ms3/pix/ms3x ... wiring.png (new)
and
http://www.msextra.com/doc/ms3/pix/ms3x-pwms.png
and
Re: SD Card logging
That's the answer! Thanks for the updated pix.
Brian
Brian
Brian
Re: SD Card logging
Refresh the second picture. I added bulb wiring for clarity too.
Re: SD Card logging
I am needing assistance with this topic, but the diagram image links no longer work. Can someone send me images of the two diagrams in this post? I am for sure needing the diagram with the modified image that shows the bulb added as well.
1988 RX7 Turbo sand rail. 80mm Billet TB, 4) 48lb Accel disc injectors, Stock coils, MS3x V3.57, MS2/Extra w/ knock module. 10 PSI boost w/ T04 Turbo, LC-2 O2 controller, Home built Intake Manifold, fan cooled oil & intercooler, Bus 5-rib 002 Trans w/ close ratio gears, 4.86 final drive.
Re: SD Card logging
Those diagrams are in the Hardware Manual. See "Manuals" above.
