Tri-tach install on a Porsche 911 3.2L with 129+1 tooth help
Re: Tri-tach install on a Porsche 911 3.2L with 129+1 tooth
I agree James.
That was just a general question, in case of a simple replacement of the oem ecu.
In my case, if single pin signal is ok, so is high speed signal, the only issue left is a wrong setup of the cam sensor. Poll level and correc level is not important here?
Any updates? (Good or bad.)
Hello James,
Yes, update. I tried a lot of things since the 22 of March, and finally decided to change the flywheel for a more standard 60-2 from a 964 RS.
Went back from Jean's 2.0 Dual VR (That is working fine !) to a LM1815 solution I am using on my board.
The car started immediatly with the OEM VR sensor and the cam sensor using dual wheel mode.
So I can now confirm there was no problem at all with the wiring, the "old" high count speed sensor and the cam sensor.
Honestly, I have absolutely no idea why it was not working, and in the next month I'll try again with the engine out of the car. For now, I have lost so many hours and the customer can't wait more..
The only thing I have found is on the old 129+1 flywheel, there was small 5mm balancing hole on the single pin trajectory, and maybe the sensor was seeing it ??
If you have any idea, you are welcome, because right now I don't.
Ben
Ben
Man, I'd kill to get this to work on my 3.2...
I want to ditch my 36-1 wheel, it's been nothing but hell with noise problems.
I'm so done with this thing after 5 years.
'87 Porsche 911 turbocharged (Borg Warner S366/1.4 bar) 3.4L w/MS2 v3.57 running Ford EDIS-6
I gotta say... the 36-1 wheel is one of the easiest to get right. If you have problems with that, then 129+1 might be even worse. How about starting a fresh thread, with your MSQ/MSL and short description of the problems. A tooth-log, too, if your MSL shows a lot of sync-loss.
I completely agree. At the most basic level, if you're having noise problems with one trigger wheel and sensor, it's pretty unlikely the situation will improve with two wheels and sensors!
The only way I can see things improving is if the location of the 36-1 wheel (presumably on the damper) forces you to put the sensor or wiring in an electrically noisy location and the tri-tach turns out to be better because it's location (presumably on the flywheel) is different. But that's a big gamble... a much better bet would be to determine the source of the noise and deal with it appropriately.
Eric Law
I've started too many threads with the key words cutting out with no resolve.billr wrote:I gotta say... the 36-1 wheel is one of the easiest to get right. If you have problems with that, then 129+1 might be even worse. How about starting a fresh thread, with your MSQ/MSL and short description of the problems. A tooth-log, too, if your MSL shows a lot of sync-loss.
I care not to start another!
I've o-scoped, but not at high RPM and boost where the issues happen.
Not quite, I would be using the OEM trigger, which should be free of noise susceptibility being designed by an EE.elaw wrote:I completely agree. At the most basic level, if you're having noise problems with one trigger wheel and sensor, it's pretty unlikely the situation will improve with two wheels and sensors!
The factory triggering may have been designed by an EE but here's the catch....So was the conditioning circuitry in the factory ECU and they were designed to work together. You aren't using a factory ECU with that exact circuit, you are using a generic conditioner.
Support the developers!
Well, as you might know, my VR is running within a few inches from the alternator. The alternator is behind the cooling fan for air-cooled 911's. I cannot physically move the VR away from there since the alternator and crank are so close together.prof315 wrote:The factory triggering may have been designed by an EE but here's the catch....So was the conditioning circuitry in the factory ECU and they were designed to work together. You aren't using a factory ECU with that exact circuit, you are using a generic conditioner.
Porsche used a toothed flywheel (129+1) instead of a crank trigger on the 84-89's and 60-2 FW on the 90-98's.
Point is, they never used a crank trigger.
So, if I were to get the 129+1 FW trigger to decode, I would have NO noise generating components near the input circuit like I do now. But, reading the max RPM MS2 and VR can generate, leads me to believe that I would have an issue above, say 4000RPM with breakup.
My only for sure option is to change out the FW to the uber expensive 90-98, which is very heavy too.
That might be your explanation right there... alternators (and their wiring) can emit pretty powerful magnetic fields. Have you ever tried a Hall sensor instead of the VR? They can be less sensitive to external interference.Tippy wrote:Well, as you might know, my VR is running within a few inches from the alternator. The alternator is behind the cooling fan for air-cooled 911's. I cannot physically move the VR away from there since the alternator and crank are so close together.
That's too bad because from a triggering perspective, it would be a great option. Is there any chance of getting a reasonably-priced used one and having it lightened?Tippy wrote:My only for sure option is to change out the FW to the uber expensive 90-98, which is very heavy too.
Of course in general swapping a flywheel isn't nearly as easy as swapping a crank sensor...
Eric Law
Hall has crossed my mind, but then I'd need magnets on the trigger wheel, no? Or can some read just ferrous metal? Going to Googles now...elaw wrote:That might be your explanation right there... alternators (and their wiring) can emit pretty powerful magnetic fields. Have you ever tried a Hall sensor instead of the VR? They can be less sensitive to external interference.Tippy wrote:Well, as you might know, my VR is running within a few inches from the alternator. The alternator is behind the cooling fan for air-cooled 911's. I cannot physically move the VR away from there since the alternator and crank are so close together.
Well, I was pulling the engine and trans anyways since my Kevlar clutch disc can no longer handle the additional power lately, so it wasn't any additional out of the way work to do this.
No, a Hall sensor in the most generic sense would require magnets, but they make ones now designed for this exact purpose that don't... actually the sensor has a magnet in it. Wow that was a jumble of words but hopefully you understand!
Either of the two at the top of this list would work fine: https://www.diyautotune.com/?s=hall
...and actually they'd work with the 60-2 flywheel too. I think there are some here that would disagree, but I think Hall sensors are much easier to work with than VR... they're less finicky. The only downside is they require power so if you have an existing cable with only 2 conductors it would need to be replaced with 3-conductor.
Eric Law
So the ones from DIY would work with a 60-2 flywheel WITHOUT magnets?elaw wrote:No, a Hall sensor in the most generic sense would require magnets, but they make ones now designed for this exact purpose that don't... actually the sensor has a magnet in it. Wow that was a jumble of words but hopefully you understand!
Absolulely! Assuming you can get the sensor to fit where it needs to go, of course.
If you're curious, here's a datasheet for a similar sensor: http://www.littelfuse.com/~/media/elect ... et.pdf.pdf
Eric Law
Thank you Eric! I have a braided sheath that I am going to try from work first to see if I make a difference first before doing Hall. My EE coworkers use it to block noise with it on ad hoc, quick setups.elaw wrote:Absolulely! Assuming you can get the sensor to fit where it needs to go, of course.
I would pull 5V from the TPSREF wire. Shouldn't be a problem.
Tippy,
I am running an Electromotive 60-2 wheel and their VR sensor from my old crankfire set up. I have no issues with it. I did have to tweak the R52 and R56 pots on the V3.0 board at first. The wire itself is coaxial and is routed along the left side of the fan shroud and under the intake manifold to the left corner of the engine. The coaxial is carried on to MS3 via a 22 pin Weathershield connector, with the cable provided in the DIY MS3 wiring harness I bought when wiring the system. I also have 6 LS2 (514) coils mounted along the outside of the 3.2 Carrera intake runners for twin plug ignition that could be another source of EMI. Maybe the newer higher amp alternators with the built-in regulator are more noisy in your case.
Porsche 930 3.0 Slantnose
Hey Dennis,Dennis930 wrote:Tippy,
I run left of alt to center by shock tower running underneath 3.2 intake where it terminates into the Ford EDIS module. I have some LS/truck coils lying on my bench I plan on doing one day.
If I go Hall or FW trigger, this will force me to go to them since the EDIS system would no longer work.
Not sure on the alternator, but I think its an 80A? I had it rebuilt with new bearings not to long ago.
With over 3000 views, I think it is time for Dr. Cortina to make this happen!
A lot of views doesn't necessarily mean a lot of interest in using such a bastard system.
