Megasquirt ON BMW m52 Engine
Postby maxo-tt1 » Fri Dec 23, 2011 6:28 am
hello people :) i've just bought ms3x ecu and and wanna tune my car with myself :) (i've never done it before).
so if someone has any important experience, please share :)
except an ecu, what do i need to buy?
i have to buy this? http://www.diyautotune.com/catalog/quad ... p-481.html
i've seen wiring here http://www.msextra.com/doc/ms3/hardware.html
what's the difference between m50 and m52 wiring?
may i use this?
http://www.megasquirt.325ix.com/MS_to_M ... 3.3.1.html
any recommendation is useful for me :RTFM:
thanks
maxo-tt1
Re: Megasquirt ON BMW m52 Engine
Postby lastermann » Tue Dec 27, 2011 10:27 am
You don't need that ignition module, you ve COP on your car and you need to find a way to ignite your coils with MS3X spark outputs. You may also consider switching to a VW coils, they're logic level and you don't need extensive modifications. I am currently running VW coils (COP) on my M20 engine. I recommend keeping original wiring loom and using RS motorsport's cable harness instead, so you can switch to original setup at any time easily. A wideband sensor and its controller is a must, buy Innovate motorsport's LC1, and first of all make sure that you'll be able to control your Vanos, without controlling Vanos correctly your m52 engine will only go worse. In my opinion M52 engine is no good for playing, Its already perfect, If you really wanna play, buy a classic and setup MS3 on it.
lastermann
Postby maxo-tt1 » Tue Dec 27, 2011 11:34 am
thanks for reply.
its now clear about ignition.
i've bought ecu and innovate lc1 kit allready. they'll arrive on 3'th of january :yeah!:
so i'll start as soon as possible. and will write here everything i've done.
yes, vanos is really headache. i have no idea how tu make vanos work.
so its better buy m50b25 non vanos head and rebuild yes?
can y help me finding proper "RS motorsport's cable harness"
p.s
i'm from georgia, sorry for mistakes :P
maxo-tt1
Postby lastermann » Tue Dec 27, 2011 1:05 pm
http://www.diyautotune.com/catalog/1239 ... p-451.html
http://www.diyautotune.com/catalog/1239 ... -p-43.html
these are cable sets, you'll need both, don't try to build yourself, it will cost half price but with full of headache. 90% m50s have vanos, but single, yours have double vanos, (exhaust&intake) and it doubles the pain. m50 & m52 engines can also be tuned by simply reprogramming the motronic ECU, its much easier and better to do this way. MS is great for upgrading carburated and some older engines with oldest technology. Your engine has already COPs, O2 and knock sensors, Vanos etc., its a perfectly tuned engine with latest technology and I'd rather keep it original. and if you wanna modify just do it with stock ECU via connecting to OBD2 port on your car. However if your aim is to leaarn and experiment buy and e30 3.25i and play with this oldskool just as I do.
lastermann
Postby maxo-tt1 » Tue Dec 27, 2011 1:23 pm
mmm... why not biuld it myself? its easy to get db37 conenctor and build the same wiring :roll:
yes i know about motronic, but i plan turbocharger soon, and i think megasquirt is better for high boost.
and i have another problem, cant find my stock siemens ecu (ms41.1) wiring diagram :(
searched the google but nothing. any idea where to find it?
maxo-tt1
Postby lastermann » Tue Dec 27, 2011 1:45 pm
No idea about where to find it, however I want to emphasize once more, you may need your stock wiring harness if you want to revert back to stock ECU, so keep it. If you want to build your own harness you need to make soldering perfect, and require hundred meters of cable with no labelling on them, I bought harness ready and never regret it. And once more, m50 engine is not for turbocharging, its a well balanced atmospheric engine, I hope all your investments on it will pay-off.
lastermann
Postby James » Tue Dec 27, 2011 2:24 pm
Buy a wiring harness, it's so much easier!
Triumph 2000 Mk1 — 2 litre straight 6 — MS3+MS3X, 36-1, wasted spark — Install Details
Triumph Spitfire Mk3 — clockwork
Twitter
Postby maxo-tt1 » Wed Dec 28, 2011 12:37 am
mmm, its better make new wiring?
i thought about getting X88 pin connector from stock ecu, and connect it to db37 with small cables...
like that:
and if something goes wrong, it'll be very easy to return on a stock ecu.
:roll:
maxo-tt1
Postby James » Wed Dec 28, 2011 2:52 am
That's a very good idea if all the wires are available there.
Twitter
Postby hassmaschine » Wed Dec 28, 2011 10:46 am
hassmaschine
Postby maxo-tt1 » Wed Dec 28, 2011 11:16 am
hassmaschine wrote:wiring diagrams for BMW:
http://www.wedophones.com/BMWManualsLead.htm
wow. good job. thanks! :yeah!:
maxo-tt1
Postby maxo-tt1 » Wed Dec 28, 2011 1:05 pm
i started doing ms41.1 to ms3x wiring diagram.
can someone help me to check and complete it? (or maybe someone has it completed :roll: )
its a first half. i'll do full tomorrow.
ms41.1(m52) wiring diagram:
http://imageshack.us/photo/my-images/815/ms4111.jpg
http://imageshack.us/photo/my-images/845/ms4112.jpg
http://imageshack.us/photo/my-images/860/ms4113.jpg
p.s
if i use this http://www.diyautotune.com/catalog/bosc ... p-230.html
can i use stock coils? or i don't need it?
maxo-tt1
Postby hassmaschine » Wed Dec 28, 2011 1:26 pm
another reason I like doing it the way in the picture, is it makes working on MS much easier. I also don't like having the DB37 hardwired into the car - I did it that way last time, and I regret it.
hassmaschine
Postby maxo-tt1 » Thu Dec 29, 2011 9:53 am
little updated version.
changed sparks and injectors like firing order
dirrect img url: http://i39.tinypic.com/2ecq5ud.jpg
maxo-tt1
Postby maxo-tt1 » Fri Dec 30, 2011 4:57 am
ecu has been arrived today.
i wanna test it, how to connect it to computer?
its m3sx
i connected it with this cable
but in which pin does 12v goes?
maxo-tt1
Postby howelll » Sat Dec 31, 2011 2:50 am
Making a harness adapter from the old ecu case is how i did mine. My m52b28 is a single vanos, I used the obd2 m52 harness but i used a m50 cam sensor wired separate, the m52 uses CID cam sensor which i couldn't get to work. I used the old case to also hold the ignition drivers circuits to run the factory ignition coils. Your crank trigger should be in the neighborhood of 325 degrees but you should verify with a timing light. Is this engine in the original car or a swap to another body? just curious
howelll
Postby maxo-tt1 » Sat Dec 31, 2011 5:03 am
howelll wrote:Making a harness adapter from the old ecu case is how i did mine. My m52b28 is a single vanos, I used the obd2 m52 harness but i used a m50 cam sensor wired separate, the m52 uses CID cam sensor which i couldn't get to work. I used the old case to also hold the ignition drivers circuits to run the factory ignition coils. Your crank trigger should be in the neighborhood of 325 degrees but you should verify with a timing light. Is this engine in the original car or a swap to another body? just curious
yes the engine is in original car.
hm, useful info about cam sensor. thanks :RTFM:
to make my stock coil work, i gonna buy this
its right?
can u share your ms41 to ms3x wiring diagram please? :roll:
maxo-tt1
Postby jsmcortina » Sat Dec 31, 2011 8:40 am
maxo-tt1 wrote:ecu has been arrived today.
All the info you need is in the manual.
Read the MS3 manual starting at the QuickStart page. http://www.msextra.com/doc/ms3/quickstart.html
Postby maxo-tt1 » Sat Dec 31, 2011 8:57 am
thanks, useful link.
i just wanna know in which pin 12v goes(i care about that thing. dont want to connect it in wrong pin and damage something). is it 28pin (brown) on v3 mainboard?
thanks
maxo-tt1
Postby jsmcortina » Sat Dec 31, 2011 9:14 am
Yes. Connect FUSED 12V to pin 28 and ground to any of the ground pins.
Next
Return to MS3 General Support
Users browsing this forum: Yahoo [Bot] and 8 guests
