rpm is white line yes? it is shown when i try to start engine... for example from time 228 to 230, rpm signal have to come all time? while just opened ignition?protomor wrote:There's no RPM signal in this datalog. Can you spit out a composite log and trigger log for me?
edit: too lazy to look back.Do you have the 10k resistor in line with your crank signal? If not, it's def needed.
i dont know how to split it... i will search now how to do it...
resistor ? no, i use resistor only in start circuit...
no other resistors i use...
so i need to buy 10k resistor yes? how much watts?
here have to go resistor yes?
also maybe someone knows what are that 3 wire that comes in crank sensor? i;ve tested it and 1 is ground, second(yellow) comes from ecu and i got ~3V in it... and 3 is red and not comes any voltage in it...
on stock ecu, comes 5v in yellow wire...
