VSS output for S2000 speedo (145000ppm)
Re: VSS output for S2000 speedo (145000ppm)
So does that mean if the output Scale is set to 145000, there would be 145000 pulses per mile regardless of the input rate (assuming the VSS input ppm were accurate)?
A2 VW GTI 9A - MS3/3X
That's my reading - 4000 pulses on the input side tells the MS3 that you've traveled a mile, by which time it's sent 145000 pulses to the speedo. The question now becomes just how 'hard' the current output limit of 65535 ppm is.
It would be really good if that limit could be changed in the firmware - to get us to the 145000 ppm
fun is not a straight line
Sven
Sven
