by UnaClocker » Sun Mar 04, 2012 3:33 pm
When using the Chrysler 2.2/2.5 mode in wasted spark mode, I found that Coil A actually has to be hooked to Cyl 2/4 rather than 1/3. This tells me it's interpreting the trigger wheel 360 degrees off. Am I correct in that assumption?
If this is the case, would it also be firing the wrong injectors, when in full sequential mode?
The firing order is 1/3/4/2, I have A going to 1, B to 3, C to 4, and D to 2. What would be the correct order if it's off by 360 degrees? A to 4, B to 2, C to 1, and D to 3?
UnaClocker on Fri May 18, 2012 7:57 pm, edited 1 time in total.
