Eheh ok, we have removed the teeth from the crank yesterday, This morning i'm gonnasmake a new gasket and we will try this setting. Hope this will get better results.taylorhoff wrote: Our crank wheel is modified with one tooth removed, making it a 12-1 wheel, which changes the definition of what tooth #1 would be. But in any case, our tooth #1 angle is approximately 0 degrees.
Yes, we still use the cam sensor as well, with two teeth shaved off of the original 3-tooth wheel.
Last time we have checked with the timing light and ... from 15° to ... 25° nothing happened and suddently when it goes to 40° advance it worked .... so there is a big step in the advance and we cant go exactly to what is written on the spark map.
At the lastest new, because all the schools here in quebec are in strike, we might have to cancel our trip to detroit. If so, we might put fire to the ms3 and buy something else
