Alpha 17Matt Cramer wrote:What firmware are you using?
Any particular reason you're not on release code?
Flex fuel content gauge is broken in the release code.
It will sync with any code. The issue is that the crank signal is inverted so the phasing is 360° crank degrees out. Firing order is supposed to be 1-3-4-2, but I have to wire it 4-2-1-3 to make the engine start. The MS thinks TDC on 1 is TDC on 4.Matt Cramer wrote:Are you able to get it to sync with release code?
There are 3 positions for the tach selection jumper. You've tried 2 of them. Try the third. The input signal HAS to get re-inverted that way.opel wrote:Why didn't moving the jumpers invert the signal?
OK did that, crank signal looks good. Cam signal appears inverted. No RPM shows in TS. Switched ignition input capture, RPM's flash from 0 - cranking RPM rapidly. So is the camshaft signal VR or Hall? I think it is VR, isn't that the default configuration for the MS3X board? How do I go about inverting the cam signal?SymTech Laboratories wrote:To clarify, try moving the jumper shunt on J1 to 5-6.
What about using an Op amp with a gain of -1 to invert the signal? LM324?opel wrote:OK - cam signal definitely inverted. Is there a quick and dirty way to invert?
I started with both signals inverted. The only way the engine would run is if I wired Spark A-4, B-2, C-1, D-3, this tells me that the MS3 is 360 crank degrees out of phase. (firing order is 1-3-4-2) I did not realize until later that both signals were inverted. Now I have the correct crank signal, but my cam signal is electrically inverted.jsmcortina wrote:Hang on??? The topic started with the cam signal being inverted compared to the crank signal. You've now inverted the crank signal, so surely they should be matching up now?
Both signals inverted causes me to wire Spark A-4, B-2, C-1, D-3, which is wrong.SymTech Laboratories wrote:It's okay if both signals are inverted; you don't want one inverted and one non-inverted. The way your ECU was originally configured should have generated a non-inverted crank signal and an inverted cam signal.
Is this a standard 2.0L Neon engine, or is it a 2.4L?
Dstach wrote:Sorry to bring back such an old thread!!!! This is the only place I've found my problem. I have the exact same problem, My crank was inverted, fixed with j1 on 5 and 6. Now my cam in inverted. I however am running a 2.4 swap. How did you get this problem fixed? Again sorry for bringing it back.
