SD Datalogging Question
General support questions and announcements for MS3. See also www.ms3efi.com for MS3 information
Postby Scottie-GNZ » Wed Apr 04, 2012 7:54 pm
Got the engine running pretty good and plan to test at the strip Friday and would like to use SD datalogging with a button. Tested it today but it did not work and after re-reading the documentation I think I should be using a momentary switch instead of on an on/off. Can someone please verify this. When I turned the switch on, I got the red SD indicator but when I turned it off, the indicator did not go off. I turned the switch on then off again, then the indicator went out. Tried to do an import and got the "please wait" message but it did nothing.
TIA
Scottie
Turbo LS Mustang
8.74 @ 156.8
Scottie-GNZ
Re: SD Datalogging Question
Postby jsmcortina » Thu Apr 05, 2012 3:27 am
Yes you need a momentary push button.
If you aren't using the LEDs on the Megasquirt case for anything (e.g. "LED spark") then configure one of them as an SDcard logging indicator, that will help you understand what's happening.
I can supply, repair or upgrade Megasquirts in UK.
Postby Scottie-GNZ » Thu Apr 05, 2012 5:07 am
That's what I thought. Thanks!
Scottie
Turbo LS Mustang
8.74 @ 156.8
Scottie-GNZ
Postby jsmcortina » Thu Apr 05, 2012 5:16 am
Scottie-GNZ wrote:That's what I thought. Thanks!
That's also what's shown in the manual (!)
Return to MS3 General Support
Users browsing this forum: Google [Bot] and 6 guests
