by kizzoalfa » Tue Jun 19, 2012 2:16 pm
I just checked again: (just came back from my garage)
End pressure is 5.2 Bars in all of the cylinders.
Spark plugs are as they should be. (Light brown.)
Measured compression ratio and it is 7.8 : 1 (I used oil to fill one of my cylinders, so it is valid.)
As I looked into the cylinders the piston tops are shining a bit so there must be some oil. Also I have some oil on the spark plug threads.
I attached pictures about my spark plugs. You can see the oil around but the ignition must be Ok since the center electrodes are burnt well (also checked megasquirt dwell time again today and changed back to 5ms from 5.5ms, no change in misfire).
One more thing I think we need to clarify, and it is the meaning of misfire. What I have is a small drop in engine pull, it is looks like one burn is not complete (AFR goes from 13 to 13.5 so unburnt fuel probably present or ignition not complete) but it is not a big boom, it is how I can say similar like you cruising and set AFR to 16:1 and over that you feel somebody is pushing back the car you have some not complete ignition randomly. (I do not know what is the right english word for this.)
Thanks,
Zoltan
- Attachments
- 2nd cylinder.jpg (271.88 KiB) Viewed 233 times
- 3rd cylinder.jpg (367.47 KiB) Viewed 233 times
Alfa Romeo 75 2.0, Supercharged by Eaton M45, MS3
