Low Imp Injectors
Peter Florance
Re: Low Imp Injectors
Post by Peter Florance »
bytesandbolts wrote:Hi Peter,
Yes my grounding is already setup the same to the diagram you mentioned.
I sourced a 4ohm resister in the end to get my injector working, all set up correctly now.
Thanks again
Ok good.
Of course you don't need the PWM when using the resistor.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
bytesandbolts
Post by bytesandbolts »
Yes I decided to avoid the PWM route as I was unsure of the correct PWM values for my injector. Using a resistor in the end, was just so much easier.
MS3X powered 1974 Mk1 Escort Turbo
