Maximum Value for PW and injectortiming?
General support questions and announcements for MS3. See also www.ms3efi.com for MS3 information
Postby Activate » Sat Jun 09, 2012 1:42 pm
I have a problem with the Pw I think.
I have a 410 engine with a KB supercharger with propane injectors with P+H boards.
The idle PW is about 4.7 but when I am going to accelerate it is going up to 28 Sec it is not even at WOT then.
The engine is running really rough then, so I don't want to try it at wot.
The engine had a rough idle before I have tried to use the Idle advance( I hope I have done right? )and to lower the injector small pulsewidths, I dont have the good value for it.
The value for the injectors I get fro Bigas are :minimum impulse 2,8ms , Speedup 4ms,opening time 2ms ,close time 1ms, coil 3 ohms,
How I must use this data?
test.msq
(139.29 KiB) Downloaded 9 times
test.zip
(339.2 KiB) Downloaded 9 times
Thanks and greetings,
Erik.
My MSQ and log file are here :
Activate
Re: Maximum Value for PW and injectortiming?
Postby Activate » Mon Jun 11, 2012 4:36 am
up?
Activate
Postby billr » Mon Jun 11, 2012 8:55 am
I have very little experience with propane (fork-lift trucks only), but would need to have some idea of what the injector flow-rate is to even discuss your problem. Without knowing the flow, in something like Kg/hr or liter/hr, PW is indeterminate. A "410 engine", is that a 410 cubic-inch engine, probably a V-8?
billr
Postby Activate » Mon Jun 11, 2012 9:03 am
Hello Bil,
It is a 410 Cui and it is a V8
Erik
Activate
Postby billr » Mon Jun 11, 2012 9:11 am
Can you find flow-rate for the injectors?
billr
Postby Activate » Mon Jun 11, 2012 9:17 am
I have tried it but al I get are these value's : :minimum impulse 2,8ms , Speedup 4ms,opening time 2ms ,close time 1ms, coil 3 ohms
Erik.
Activate
Postby billr » Mon Jun 11, 2012 9:50 am
Post make and P/N of injectors, maybe someone else knows. (Make is "Bigas"?) If we can't find data, then I think you will have to flow them and measure. Determining "req_fuel" is just a big guess if we don't know injector flow.
billr
Postby jsmcortina » Mon Jun 11, 2012 9:59 am
I've not heard of "speedup" in this context before?
The dead time in your MSQ looks wrong though, where did your 2.4ms come from?
From the specs there, opening time = 2ms, closing time = 1ms. So with the same driver your dead time = opening time - closing time = 1.0ms.
I can supply, repair or upgrade Megasquirts in UK.
Postby Activate » Mon Jun 11, 2012 2:08 pm
Hello James,
Thanks for the reply
The 2.4 is just a value I have put in the MS.(that was the value that I get some idle)
I must use 1Sec. for the deadtime at A?
What curve must i use?
Must I change other value's?
Erik.
Activate
Postby jsmcortina » Mon Jun 11, 2012 2:16 pm
Yes, from the data you've presented I believe that 1.0ms is the dead time (if anyone thinks differently, please post.)
Dead time curve 1 looks feasible.
Curves 2,3,4 are bogus - where did they come from?
Postby Activate » Mon Jun 11, 2012 2:24 pm
Thanks James for the quick reply
I really don't know how the other curves came there.
Must I put the 1 sec only by A or also B and further?
Erik.
Activate
Postby jsmcortina » Mon Jun 11, 2012 2:41 pm
You have the _option_ to put individual dead times in the case where you have measured each injector. For 99% of users though the single number for all injectors ("same" setting) is sufficient.
Postby Activate » Mon Jun 11, 2012 2:47 pm
Thanks.
I will put them al on 1 sec and see if it runs better!/
I hope that my PW gets better now.
Erik.
Activate
Postby jsmcortina » Mon Jun 11, 2012 2:58 pm
Activate wrote:I hope that my PW gets better now.
Your PW will be about 1.4ms less. But the dead time _I_believe_ should be more accurate.
You will need to add more fuel to the idle areas of your VE table.
Postby Activate » Mon Jun 11, 2012 3:04 pm
Thanks for the answer!
I will try that.
Wich value I must put in the mainboard injectors?
What is the max PW that is safe?
Erik
Activate
Postby jsmcortina » Mon Jun 11, 2012 3:06 pm
What injectors do you have connected to the mainboard injector outputs?
Not sure what you mean by "safe" ?
Ensure the dutycycle does not exceed about 85%
Postby Activate » Mon Jun 11, 2012 3:13 pm
I have no injectors connected to the mainbord.
I will look at he dutycycle.
Erik.
Activate
Postby billr » Mon Jun 11, 2012 5:11 pm
Activate,
You keep saying 1 sec; do you understand that should be 1 milli-second?
Edit: I had never heard of "Bigas", so I looked on-line for background info. I came across your MS thread from early 2011, with many of the same issues being discussed; including the need to flow the injectors since Bigas won't help you. Do it.
billr
Postby Activate » Mon Jun 11, 2012 9:52 pm
Hello Bil,
Yes I am saying 1 Sec, of course it is 1 Msec.....
What will be the best way to test the Injectors?
Erik.
Activate
Postby jsmcortina » Tue Jun 12, 2012 1:30 am
(Being pedantic, it is one millisecond, not a megasecond.)
I don't know how you do test gaseous injectors with a gas. Seems you would need far more specialised equipment than when using a liquid.
You _might_ have success with injector test fluid : http://www.msextra.com/doc/ms3/injdeadtime.html
Next
Return to MS3 General Support
