Sync Loss reason 17 or Reason 2
Re: Sync Loss reason 17 or Reason 2
Please post fresh logs. Turn on the noise filter on crank and cam (but set the filter times to zeros) - this will make the composite log capture both edges of the crank and cam signals.
Ok ill do that.jsmcortina wrote:Please post fresh logs. Turn on the noise filter on crank and cam (but set the filter times to zeros) - this will make the composite log capture both edges of the crank and cam signals.
Sean
2005 Kawasaki STX-15f Jetski
1498cc I-4
12.5:1 CR
46mm throttle bodies
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Plugs out and plugs in.
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Any thoughts?
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
The cam needs to be set to "Rising" for sure. I can't tell on the crank what polarity is needed, but the compression effect is pretty horrible.
Its a 180 degree flat plane crank which is part of the problem. Whats weird is that the rpms increase with the plugs in, 300 out and 450 in.
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
I updated to the latest release firmware and now I only get 8 teeth in between the cam pulses. thoughts?
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Please post a composite log and current MSQ. Difficult to comment otherwise.
I thought you went back to the stock 8/1 trigger wheel a page back.................on March 10thsmokeysevin wrote:I updated to the latest release firmware and now I only get 8 teeth in between the cam pulses. thoughts?
Sean
just sayingsmokeysevin wrote:Swapped back to the 8 tooth wheel and am setting timing, looks okay but I wont know for sure until tomorrow. its too late to test tonight.
Sean
wd
I am on the 8 tooth wheel now but there should be 16 teeth between cam pulses not 8 because the crank has to rotate 2 times for the cam to rotate one complete time.
Ill get the logs in a few minutes.
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Tune and Composite log,
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Fresh logs and tune from this morning.
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Im switching back to the 24-2 wheel, I think the cam sensor is what is causing the problem based on the above logs.
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Are you using resistor type plugs?
wd
wd
Yes, cr9ekwrenchdad wrote:Are you using resistor type plugs?
wd
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
I am considering chucking this d*** thing out a window at this point. I cant get it to sync on just crank either. I have been through the harness with a fine tooth comb and have come up dry.
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
added a 10k resistor and got a new log. Tune is the same, can I add a 10k resistor on the cam sensor?
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
Well its sort of running, for whatever reason the sync loss issue still happens every once in a while but not while its running, the logs show sync loss but a lot of the time the engine is fully stopped then develops a rpm value on the log but not on the actual engine. The other sync losses are just the engine coming to a stop which makes sense.
Now onto more pressing matters, what the heck is going on in with the rpm fluctuation here?
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
I see you are running AlphaN for load, but when at only 1.8 TP I am seeing RPMs above 2000 so thinking you are getting some air in from somewhere? That could be why your revs are swinging so much?
later wd
later wd
I checked for leaks and couldn't find anything, I did some searching and made some changes and here is what I have now, The logs show some weird stuff going on. The seq pw will go along at a reasonable rate and then shoot up for no reason that I can see, the spark advance will go along reasonablly and then fall by 10 degrees or so then slowly climb back up again with no sign or reason.
See what you can, I need to get this thing to where it will start and idle around 1500 rpms without having to mess with the throttle.
I altered the timing map at the bottom end and it seemed to make the engine more stable but I am still getting huge rpm swings with no obvious reason.
Data log on google drive here
https://drive.google.com/file/d/0B6Oy77 ... sp=sharing
Sean
Sean
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
1498cc I-4
12.5:1 CR
ported head
Ferrea valves
38# injectors
