I do know that the engine must be running (see RPM) for it to "see" anything due to the knock window being timing dependent...Mario wrote:Great, thanks for the info! I just didn't remember them being on all the time on the last one I did. Then again it was a 3.57 so the led's where inside...
I'm getting odd behavior though. On the bench I get a noise floor of 2.5-3.5%. When I put it in the car all 6 cylinders sit at 0%. running or not.
Figured that out doing tap tests with a crescenthammer to see if it was seeing anything.
Hope to get a second sensor installed for front pair (1/3) RSN, but the cars down for a few days,
Note: brake lines are totally incompatible with drill bits.
I just picked a new sensor up at O'Reillys for $16, late Neon sensors are common as salt, and the auld Bosch injector connector fits perfect.
