Wiring up a 1UZ VVTi Motor - The Triggers and VVTi portion
Re: Wiring up a 1UZ VVTi Motor - The Triggers and VVTi porti
There is some experimental support for this in the latest MS3 code, although it doesn't seem to be fully tested from what I've seen.
Mario
Post by Mario »
Thanks Matt, I checked the MS3 Alpha code but didn't see anything specific to this application. |
Smohekey, have you made any advances?
1967 Beetle My test mule
The Dub Shop
Facebook
Megasquirt for life!
As per my earlier post, I'm still waiting on composite logs to be posted before I can comment any further.
smohekey
Post by smohekey »
No, not yet. My 3uz build has been put on hold while I finish another build I started years before.
280GE 1JZ
Post by 280GE 1JZ »
Actually I posted several times about this motor and all the logs I gathered.
http://www.msextra.com/forums/viewtopic ... ti#p397738
Here's my logs.
I wired the Crank sensor to CKP, Left vvti sensor to CMP and right vvti sensor to digital frequency in2. Both vvti sensors goes through Jbperf dual VR board. I hope this datalogs is enough to create a new decoder. Let me know if any more data is needed I'll be very happy to help. Thanks all.
Regards,
Doddy
PS: I tried using 2jz vvti decoder, MS3pro reads no lost sync, but the timing is way of. and the signal is slightly different from 2jz vvti.
280GE 1JZ
Post by 280GE 1JZ »
Hi James,
How is it with my logs? Can you use it to make new decoder? Thanks.
Doddy
280GE 1JZ wrote:PS: I tried using 2jz vvti decoder, MS3pro reads no lost sync, but the timing is way of. and the signal is slightly different from 2jz vvti.
How many degrees off?
Please post a datalog from cranking and the matching MSQ.
Marc D
Post by Marc D »
I'm also curious on progress, looks like were making some. Keep us updated
phoenix3d
Post by phoenix3d »
Yeah Same here...
Got a VVT-i Project coming up within the next month....
Hope to have something for then;-)
Cheers
Gordon
mr3uz
Post by mr3uz »
Hi Guys,
My best mate is aToyota trainer and a diagnostic tech for lexus. Let me know what data you need in relation to the 3uz vvti stuff and I'll get it all for you.
I have a 3uz going into a hotrod project so if we can get this working I'll use it for sure.
Cheers
phoenix3d
Post by phoenix3d »
Hi All...
Has there been any updates for the UZFE VVT-I setups....
Got a Job in next week and really need assistance with this...
PLEASE HELP????
Got the MS3-Pro, setting up the Additional VR Inputs circuits required for the relevant Pickups....
Kidest Regards
Gordon.
ray190te
Post by ray190te »
Hi Folks
Is there any news/progress on this install?
Regards.
ray190te
Post by ray190te »
Hi
I have just completed a successful install on a 3UZ-FE including VVTi.
PM me if I can help you.
Gon8289
Post by Gon8289 »
ray190te wrote:Hi
I'm looking to run my 3uz vvti with manual transmission How could I wired ms3pro to my set up? Is your set up have vvti running fully?
IndulaChandrasiri
Post by IndulaChandrasiri »
ray190te wrote:Hi
Hi sorry for reviving a dead thread but can you send me the details for this build ray190te
