Wiring up a 1UZ VVTi Motor - The Triggers and VVTi portion
Re: Wiring up a 1UZ VVTi Motor - The Triggers and VVTi porti
There is some experimental support for this in the latest MS3 code, although it doesn't seem to be fully tested from what I've seen.
Thanks Matt, I checked the MS3 Alpha code but didn't see anything specific to this application. |
Smohekey, have you made any advances?
As per my earlier post, I'm still waiting on composite logs to be posted before I can comment any further.
No, not yet. My 3uz build has been put on hold while I finish another build I started years before.
Actually I posted several times about this motor and all the logs I gathered.
http://www.msextra.com/forums/viewtopic ... ti#p397738
Here's my logs.
I wired the Crank sensor to CKP, Left vvti sensor to CMP and right vvti sensor to digital frequency in2. Both vvti sensors goes through Jbperf dual VR board. I hope this datalogs is enough to create a new decoder. Let me know if any more data is needed I'll be very happy to help. Thanks all.
Regards,
Doddy
PS: I tried using 2jz vvti decoder, MS3pro reads no lost sync, but the timing is way of. and the signal is slightly different from 2jz vvti.
Here's my logs.
Regards,
Doddy
Hi James,
How is it with my logs? Can you use it to make new decoder? Thanks.
Doddy
Doddy
How many degrees off?280GE 1JZ wrote:PS: I tried using 2jz vvti decoder, MS3pro reads no lost sync, but the timing is way of. and the signal is slightly different from 2jz vvti.
Please post a datalog from cranking and the matching MSQ.
I'm also curious on progress, looks like were making some. Keep us updated
Yeah Same here...
Got a VVT-i Project coming up within the next month....
Hope to have something for then;-)
Cheers
Gordon
Cheers
Gordon
Hi Guys,
My best mate is aToyota trainer and a diagnostic tech for lexus. Let me know what data you need in relation to the 3uz vvti stuff and I'll get it all for you.
I have a 3uz going into a hotrod project so if we can get this working I'll use it for sure.
Cheers
Cheers
Hi All...
Has there been any updates for the UZFE VVT-I setups....
Got a Job in next week and really need assistance with this...
PLEASE HELP????
Got the MS3-Pro, setting up the Additional VR Inputs circuits required for the relevant Pickups....
Kidest Regards
Gordon.
PLEASE HELP????
Kidest Regards
Gordon.
Hi Folks
Is there any news/progress on this install?
Regards.
Regards.
Hi
I have just completed a successful install on a 3UZ-FE including VVTi.
PM me if I can help you.
ray190te wrote:Hi
I'm looking to run my 3uz vvti with manual transmission How could I wired ms3pro to my set up? Is your set up have vvti running fully?
Hi sorry for reviving a dead thread but can you send me the details for this build ray190teray190te wrote:Hi
