I have MS3 + MS3X + Knock Module...
http://riceracing.net/Gallery/displayimage.php?pid=917
Before motor run, it has Hall sensor, 12-1 wheel... firmware 1.0.2
Now i make change:
Wheel 12-1 to 36-1
http://www.autotune.fi/tuote/706/trikke ... 153x67x6mm
Sensor VR (BMW?):
http://www.autotune.fi/tuote/338/vranturi-tarvike-bmw
Sensor ground come to Mega and Signal is shieldet and its go ground in mega too.
I cut XG1 - XG2
Move TACHSELECT -> VRIN
Move TSEL -> VROUT
I move R52 and R56 13 turn left(anti-clock?) to when come "click"
Update firmware to 1.31alpha
Come much errors, possible wrong .msq
I change Firmware to 1.2.1 and all looks ok, no errors.
Thooted wheel, 36 thoothg and 1 missing.
Single wheel whit missing Toothg
Now i not get motor run or looks at mega not take any "RPM"
All other sensors etc. works...
I remove MS3X card and change anything.
What i missing or make wrong?
I use registered TunerStudio 2.2.13
Plan make Full Sequ.. whit Cop coils but now i need first take motor speed come up in mega, now it show only 0.
And sorry my English, Finnish is more easy =)
What i do wrong? Solved
https://www.facebook.com/PikkiS-112502032715453/
https://www.theniceman.com/coppermine/
Ford Taunus Coupe 1975 2.0i Turbo
Ms3 + MS3x in Taunus
MS3 Pro Ultimate in PikkiS
Re: What i do wrong?
Please post a composite log of an attempted start. This will show what sort of signal you're getting.
Ok, i take that tomorror when i go garage...
I remember at i test that and its looks empty in tunerStudio...
Log to file is right i think.
I try make composite log but its empty...
#Firmware: MS3 release 1.2.1 20130316 16:55GMT (c) JSM/KC ********
PriLevel,SecLevel,Trigger,Sync,ToothTime,Time
Flag,Flag,Flag,Flag,ms,ms
Only this come...
Thre somewhere electric pictures where see what is conneth VR circuit? If need check mainboard at all is ok...
Only this come...
Proplem solved =)
VR give 4.5Vac whit startmotor...
I make mistake when make ms3.0, i forget R44,R45 and R48 some reason... I put them there and not ms3 start work and motor run.
