MS3X A4 1.8T Quattro Running and partically mapped
prof315
Re: MS3X 1.8T got trigger signal, but fuel pumpt not running
Post by prof315 »
Drunken_M wrote:I fired the car now with the 630cc injectors, it worked ok.
But, when the rpm is between 7-800rpm, and 1200rpm and i hit the gas, sometimes the rpm goes to 0rpm for a sec and then reads correct again, and it pops in the exhaust of course. Could this be a tuning/software issuw, or just some problems with the signala from the vr or cam?
Sounds like a possible sync loss. Post up a datalog and msq
Support the developers!
Drunken_M
Post by Drunken_M »
I will post a log and the msq when im home again tonight.
But i will redo all the bad wiring first, but is there any good explenation to why i dont have trigger reading when i mount the side covers on the ms3 box?
billr
Post by billr »
"Bad wiring" is a good explanation for most any problem! Get that fixed first, let's see if the triggering issues go away after that.
Drunken_M
Post by Drunken_M »
Ive wired it all with good wires and real soldering. But still the same problem, i tried to solder in the 1kohm resistor from 5v to vrin. Then i had to adjust the r56 pot again, and the sync problem was not there anymore, i tought. The problem now appears at 3000rpm instead.
Paul_VR6
Post by Paul_VR6 »
Can you get a tooth log of a rev up there? The stock sensor on that motor, both pots fully ccw should have no sync problems past 9600rpm.
-Paul
1992 Corrado SLC 3.6 VR6 11.38@120 - MS3 Pro Ultimate - Microsquirt I/O - Can EGT - Racepak IQ3s
Drunken_M
Post by Drunken_M »
I have made some logs, but i dont need to post them, i just tried in one last attempt to change vr sensor polarity, and guess what? No more sync problems and car is running great :)
I guess all the info i got on the aeb 2 connector ecu was not correct on the vr sensor polarity.
T3Bunny
Re: MS3X 1.8T Running and partically mapped.
Post by T3Bunny »
Glad to hear it! Safe tuning, and please post updates! Video?! :mrgreen:
Forget the porn, my bathroom is full of car manuals...
1977 Rabbit (retired)
1991 Cabriolet (retired)
Drunken_M
Post by Drunken_M »
Thanks T3Bunny, car is running fine now. Just have to do some fine tuning and ignition timing on the dyno, but i have to wait until my 4bar map sensor is mounted.
I will try to make a video when its finished, but i can post some pics of the car now though :)
And a bad video of some turbo flutter :)
