arran wrote:Dashpot is just going to have a transient affect on the idle, it adds duty for a short amount of time to make it a soft landing into the idle set pointrichyvrlimited wrote:AbeFM wrote:Ok, I'll look there. I'd played pretty fast and loose with the tables around/under idle trying to get higher AFR's after I had CL idle in place.
It seems when it's cold, a higher dash-pot would solve some issues. Or mask them
And yet when cold i want zero dashpot, (causes an unnecessarily high idle) but need it when warm.
Well aware of what dashpot does. When cold and you already have a high idle, there's absolutely no reason to need more idle valve duty.
As a double whammy, when cold the increase in idle speed from the amount of dashpot adder to the idle valve is far greater than when warm.
When cold my dashpot amount increases idle speed by 350rpm or so. When warm it increases it by 150rpm
