bump box ms3x
bump box ms3x
Has anyone configured their MS3x for a bump box to interupt the trans brake just enough to light the second bulb when staging with boost and rpm up there?
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
2.4 turbo rwd
9.86@133
Re: bump box ms3x
Re: bump box ms3x
Would I be ok using nitrous output for grounding my trans brake relay. also how would I go about inverting it so it grounds the relay so the brake works then removes the ground momentarily to bump into the beams
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
2.4 turbo rwd
9.86@133
Re: bump box ms3x
How much current does your trans brake solenoid draw?
Re: bump box ms3x
It draws a maximun of 7 ampsMatt Cramer wrote:How much current does your trans brake solenoid draw?
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
2.4 turbo rwd
9.86@133
Re: bump box ms3x
I'd use an external solid state relay.
Re: bump box ms3x
I'm using a Chrysler one.Matt Cramer wrote:I'd use an external solid state relay.
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
2.4 turbo rwd
9.86@133
Re: bump box ms3x
I only have a one wire Trans brake. Right now I have the power button triggering a standard rely to ground launch in wire
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
2.4 turbo rwd
9.86@133
Re: bump box ms3x
You need to wire up a relay to control the trans brake and the MS to control the ground side of the relay.
2000 Mustang GT 4.6 4V, MS3 Fully sequential,Twin 6466's,Glide, full fuel system 1100 WHP
8.78@160
Stock 2V Longblock- SAE 472Hp/469Tq on E85
11.27@121
8.78@160
11.27@121
Re: bump box ms3x
Thanks that's what I'm asking how do I get the mega squirt to control a grounded to control relay see the brake is on ground then unground for the bump.
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
2.4 turbo rwd
9.86@133
Re: bump box ms3x
I'd like to use pte4 input for bump switch. It say can be used for input or output. Do I need to use a jumper to make this an input ?
87 Daytona Shelby Z
2.4 turbo rwd
9.86@133
2.4 turbo rwd
9.86@133
