Megalogviewer and status indicators
I promise I've had a search but I can't locate information on how I can get Megalogviewer to display some fields.
How do I display when IdleVE is active?
How can I display when my Air Conditioner is active? It uses the LaunchIn input.
How can I display when closed loop idle is active?
How can I see when DashPot is added?
How can I see when Fan is active?
How can I see when Idle Advance is active?
I am having a lot of trouble getting my idle to behave consistently with the AC on, it settles nicely 10 times then for no reason I can see on the 11th test it will stall, or almost stall, so I want to have more visibility of the variables involved.
Does it involve bits within PortA, B, C etc, or the status registers?
Thanks for any advice,
Arran
Arran
http://web.aanet.com.au/arran
Re: Megalogviewer and status indicators
A shortcut list, or the ability to add indicators would be cool.
I was just daydreaming the other day how neat it would be to be able to run the ddata log using the TS dashboard.
Port K seems to correlate in my data logs with the AC.
Can't yet see the other data
Searching google for hits on port rather than status:
http://www.msextra.com/doc/ms1extra/COM_RS232.htm
Different processors are used between MS1, MS2, MS3 so the ports are all different.
The CPU ports for MS3 are listed in the manual:
http://www.msextra.com/doc/ms3/hardware.html#pins
That link is a great help. I had not joined the dots as to the connection between entries in that table and the portX registers.
To help others I'll elaborate a bit.
In the table linked by James towards the bottom is A0, A1, A2, ... A7.
If you have a look in Mega log viewer there is a data stream selectable called PortA, the 8 bits correlate to A0, A1 etc in the table. For example, remembering the engine is a rotary, with a sequential setup under a wideish open throttle I would expect to see primary and secondary injectors active, A=front primary, B=rear primary, C=front secondary, D=rear secondary. I can see PortA = 5, being 00000101, so front Primary and front secondary are active. Next sample the value of PortA=10, being 0001010, so rear primary and secondary are active.
PortB in my data is flatlined which should be spark so I'm unsure what is going on there.
PortK bit 2 is the Launch-in which is my AC compressor
I can't see how to track some other parameters, as mentioned Fan, Idle VE, Idle advance,.....
I'm also interested in the port status. Is there any overview, where I can see which port is active for which function/output? I'm using MS3 1.4.6a
Especially I would like to see:
-ALS feature active
-flatshift active
- which cylinder is cut spark and/or fuel
thanks for your help
Julian
-ALS feature active
-flatshift active
Julian
The recent MS2 and MS3 TunerStudio Reference manuals spell out all of the status bitfields in the Datalog fields section.
i was thinking that also.nathaninwa wrote: I was just daydreaming the other day how neat it would be to be able to run the data log using the TS dashboard.
That would be good.grom_e30 wrote:i was thinking that also.nathaninwa wrote: I was just daydreaming the other day how neat it would be to be able to run the data log using the TS dashboard.
