Hall gear tooth sensor requirements
Re: Hall gear tooth sensor requirements
I did the V3 board, not the V3.57 but it looks like on your board, in addition to the R57 add, you jumper JP1 pins 2-3 and J1 pins 1-2. This connects the Opto circuit's input to the Tachin and its output to the processor. In addition to that, 2 notes (note 2 and 3 on sheet 3 of the V3.57 schematic) say to jumper across D1 and D2 as they are unnecessary with a 5V referenced Hall sensor.
A2 VW GTI 9A - MS3/3X
WalterClark1 and James: Thanks for the correction. I'm going to have to go back and review my installation of 2 years that is running really well. Maybe I am misremembering how I installed it. Apparently the two resistors in my system result in a bias that is in the acceptable range for the sensor/and board circuitry. Thanks again.
Brian
MS3-3X v1.3.0; TS Ultra 3.0.28; 911SC 3.0L; 3.2 intake; 2 Spartan O2 sensors; LS-2 coils; 60-2 geartooth and hall; dizzy hall
So long as it works... leave it alone !!
Sage advice from James:
And ... I will leave it alone unless there is the possibility of damage ...
Brian
Oh, yes -- words to live by. But in the nature of DIY and learning, I went back and checked. my setup is a v3.57 board with 1K at R57 which provides bias between VCC (+5v, right?) and the input signal. At the crank, 1K across +12v and Hall signal output. The Hall is a gear sensor looking at a 60-2 crank wheel. This has been running almost 2 years without a hiccup. Just curious -- can this be hurting anything on the v3.57 board? Does this arrangement effectively provide a +7v signal to the tach select circuit?So long as it works... leave it alone !!
Brian
Brian
I would try getting rid of the 12V pullup. It will be backfeeding something like 24mW into your 5V supply when the halls not grounding.
I can see nothing that would be damaged by leaving it alone.
Agreed. 24mW will be simply dumped out the D19 Zener to ground without any fuss.walterclark1 wrote:I can see nothing that would be damaged by leaving it alone.
As of now-I have both resistors(board and sensor) and rpms are rock steady.
Steve
1971 Datsun 240z 3.2 L6 1975 EFI intake plenum 60mmTB with 42lb Bosch injectors
MS3x 3.57 Ignition LS1 coils running full sequential
!983 Nissan 720 MS2/3.57 ported efi 26lb Bosch VW 4 tower ignition wasted spark
Removed external 1K resistor from sensor wiring-RPM's still solid!!!!!!!!
Steve
Reviving an old thread since it should be relevant to my current issue. First off, please excuse any mistakes I made uploading my tune, but I hope I got it right. I also uploaded a datalog showing what's happening. The pic is of my trigger wheel.
The last post in this thread everything was going good, and then I had engine(mechanical issues-I thought). It was running issues that I thought were not related to my MS, but maybe they were. Anyhow, a year later and rebuilt motor I'm backing running again, but my engine won't go past 4k or so.
I'm running a Cherry Hall gear tooth sensor GS 100502. This set up worked originally, but now the engine completely cuts out and backfires most of the time at around 4K. I have tried every adjustment from the recommended 1.5mm down to a 1/4 turn. The engine runs smooth at anything below this rpm. idle is a bit erratic, but this might be a carb tune issue. I have replaced the sensor with a new one with no effect.
If you read the complete thread there was confusion on the pull up circuit required. I took my ECU to an electronics shop to have the work done because I didn't feel
confident I could do it. As I said before, it ran and tached out fine all the way to 7K. I got brave and opened up the unit yesterday to make sure all the work was done correctly according to the MS instructions. I must say that it still is a bit confusing to me. I know my sensor needs a pull up resistor, because it doesn't come with one built in. So looking in my unit it seemed all jumpers were made. The only questionable thing I saw was the pull up resistor. Not a electronics guy, not sure what the resistor should like , but the one in this unit was really small and had the number 001 on it. I guess I was expecting a peanut shaped resistor with bands of colors, but no such thing. So maybe there isn't a resistor there.
Hoping you can find something wrong with my tune or see something with the logger.
I just found sync loss 2, but have no clue why.
Steve
A little more background. I have been careful to keep all my sensor wiring away from any power wiring. My sensor wiring runs thru a different hole in my firewall. I am only running a CLT and AIT at the time. The Cherry Hall sensor is running off the TPS 5V wire, but I run no TPS. I used the dedicated sensor ground black/white stripe for the sensors. I attached a pic of my grounding set-up.
The hall sensor uses the ground that is meant for the VR/Hall(white and black in the shield loom) . My question is what to be done with the shielded part? Does this sensor get grounded at all with the black/white sensor ground that is used for the other sensors?
Steve
Nothing guys?
Well going back to Ole school dizzy and wires I got the car running fantastic. This was especially important since this was a fresh rebuild. Interesting thing happened though, the battery pretty much gave out. Looking at the date of 02/10, I'd say I got my monies worth. Then I started thinking that maybe my battery has been an issue all along. Time to switch back to the MS and see.
Steve
Well my view tally keeps going up so I won't leave anyone in more suspense. Actually just got around to getting a proper power supply and connectors to connect to my unit. Well I measured across 54 and it was only 1.5 volts. I adjusted the pot until I got it to EXACTLY 2.5 volts.
Drove car and it revs out fine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[/FIXEDb]
[/FIXEDb]
Steve
Now is there anyone good with triple Mikuni's--LOL
Steve
