When James releases the updated MS3 firmware that can make use of the CAN-EGT data through standard CAN, I will post the CAN-EGT firmware he mentioned (for the DIYA unit you have). I want to wait until then to make sure everything works together as intended.nathaninwa wrote:I've ordered two of the aem boxes, still waiting for responce from the perfect tuning guage gentleman
Edit, email sent again. And my Canegt is from DIY. Does Jean do the firmware for these?
I'll also need to look at the same option James mentioned for the Microsquirt IO-box that disables Megasquirt-CAN totally. Depending on the CAN IDs used by the AEM unit, it is possible that there could be conflicts.
