AEM 4-channel UEGO CANbus?
racingmini_mtl
Re: AEM 4-channel UEGO CANbus?
Post by racingmini_mtl »
nathaninwa wrote:I've ordered two of the aem boxes, still waiting for responce from the perfect tuning guage gentleman
Edit, email sent again. And my Canegt is from DIY. Does Jean do the firmware for these?
When James releases the updated MS3 firmware that can make use of the CAN-EGT data through standard CAN, I will post the CAN-EGT firmware he mentioned (for the DIYA unit you have). I want to wait until then to make sure everything works together as intended.
I'll also need to look at the same option James mentioned for the Microsquirt IO-box that disables Megasquirt-CAN totally. Depending on the CAN IDs used by the AEM unit, it is possible that there could be conflicts.
nathaninwa
Post by nathaninwa »
Thankyou guys. My car won't be ready to drive again till about march but would also be willing to test any firmwares if needed on the bench once the car gets wired about mid January
Post by jsmcortina »
quark2501 wrote:Got it working.
Only "problem" is that you need to calibrate all sensors together. So if you have a fifth sensor, it bad luck. Will there be a work around this James
The "Calibrate AFR" is ignored for for widebands over CAN where a lambda value is provided (AEM, Ecotrons, Innovate via IO-extender or CANEGT.)
quark2501
Post by quark2501 »
I don't understand that.
I have a plex over the ms3 ego port, when I put the aem box on, I have to calibrate the sensors as shown on this page, doing so mess up my plex. So I don't see how the calibration is ignored, maybe I have done it wrong.
Sendt fra min SM-N950F med Tapatalk
quark2501 wrote:I don't understand that.
Which page? What is a "plex" ?
quark2501
Post by quark2501 »
Plx wideband autocorrect.
Further up in this thread it tells how to configure the wideband.
That's obsolete information from before the AEM specific setting was added.
quark2501
Post by quark2501 »
jsmcortina wrote:
quark2501 wrote:
jsmcortina wrote: Which page? What is a "plex" ?
Ahh. That explains alot. I will look into updates. Thank you.
quark2501
Post by quark2501 »
One last question.
What about the backpressure sensor, is it still possible to retrive data from this sensor?
Mvh
Christian
You can still configure that through the generic "CAN Receiving".
