AEM 4-channel UEGO CANbus?
I was just reading up on a few WBO2 controller threads and started looking around when I found the 4-channel controller: http://www.aemelectronics.com/wideband- ... roller-60/
Quoting that page: "The CAN bus datastream output is compatible with most programmable ECUs, data loggers, dashes and dyno systems, and provides users with the ability to data log for each individual cylinder without tying up all of the ECU’s channels."
Can the MS3 do anything useful with the AEMnet data streams? The cost for a 4-cylinder kit is within reason, and it can even be pressure compensated for the turbo guys to measure per-cylinder AFR.
I have not read up on CANbus yet, so I am really a cluebie in that respect.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
Re: AEM 4-channel UEGO CANbus?
I looked at the datasheet for the product and Appendix A on page 19 onwards details the CAN message format. It ought to be possible with the "CAN receiving" in MS3 pre-1.4 codes to receive the data being broadcast and translate it into an AFR in MS3.
(As an aside, I wasn't able to implement CAN receiving on MS2 as there isn't enough RAM left.)
Good to know, I have to read a bit. This may belong in MS3 Development, but if I understand you correctly you are adding a generic mechanism for retrieving data from incoming CANbus data streams in 1.4? That could be immensely useful for a lot of purposes.
Aside: The 4-channel UEGO has differential outputs for the analog AFR channels, in contrast to the Innovate products. IMHO single ended analog signals have nothing to do in our applications due to the ground currents running everywhere. Differential or current loop signaling would have reduced a lot of problems. The MS3+X really should have had differential analog inputs for the generic inputs - although that could be added with addon cards.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Gentlemen, I have been consulting with Inis and I figure this would work with him for his AEM UEGO controller. Please see the attached data.
CANADC01 - 04 are the Wideband sensors, output into an ADC format that MS can understand ADC value of 0 = 0.00 Lambda, ADC value of 1023 = 6.5535 Lambda
CANADC05 is the exhaust pressure in PSIg, per the backpressure sensor. ADC Value of 0 - 0.00 PSIg, ADC Value of 1023 = 655.35 PSIg
This is the transformation of the Exhaust Backpressure Gauge
Looking at it, I know you're like: "WTF! That AFR Value is huge, it will never read right." If it were analog, yes, I'd agree. However, since it is Digital pretending to be analog, it has much better resolution. Each ADC point is .0064 Lambda or .09408 of an AFR point. Very decent resolution.
There is something wrong with your links.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
Is that better? If not, I'll have to use photobucket, but I don't like to because it is blocked at work.
Works now.
Joachim
1974 Jensen-Healey
1974 Jensen-Healey
So did this work?
I have an AEM Failsafe gauge and would like to use the AEMnet/CANbus because, well... it would be neat to do so.
Tha Daily: 2005 Chevy Blazer
Got it working.
Only "problem" is that you need to calibrate all sensors together. So if you have a fifth sensor, it bad luck. Will there be a work around this James?
Mvh
Christian
Sendt fra min SM-N950F med Tapatalk
Mvh
Christian
Is it still only setup to run the aem box on the cunbus only? I have 3 other devices using megasquirt can and want to add this aem 4 channel box as well
Look at the manual: http://www.msextra.com/doc/pdf/html/Meg ... 5-282.html. Since the AEM CAN protocol uses 29-bit IDs, there is no choice but to disable the Megasquirt protocol because there could be conflicts between protocols that could create serious problems.nathaninwa wrote:Is it still only setup to run the aem box on the cunbus only? I have 3 other devices using megasquirt can and want to add this aem 4 channel box as well
That's not something that can be fixed through an MS3 firmware update. It would either require AEM to change their protocol or have the other devices you use update their firmware to not use the Megasquirt protocol. Which devices are you using?
Thanks Jean
I'm running micro as an I/O box, CANegt box, and the perfect tuning gauge
My plan is to Black Friday another micro for the aem setup
The IO-box is compatible because it uses regular 11bit broadcasts.
The CAN-EGT could be compatible, Jean sent me some test firmware, but I've not yet completed the additions to MS3 to fully support it.
I don't know about the gauge. If it uses Megasquirt-CAN then nope. If it listens to "Dash broadcast" then yes.
Is it also possible to put a ms2e on the Canbus with Aem connected to a ms3x?
No. CAN is a bus topology where messages are sent to all nodes. So if any one node is trying to talk "Megasquirt CAN" then the AEM box will interfere with it.
Okay. But i would be possible with a microsquirt as an I/O Box.
Yes, that should work with:quark2501 wrote:Okay. But i would be possible with a microsquirt as an I/O Box.
MS3 with "Megasquirt CAN" disabled.
AEM
Microsquirt IO-box.
However... I haven't tested this. The Microsquirt IO-box does still listen for Megasquirt-CAN so could possibly be disrupted. IF that happens I can put out a version that disables the Megasquirt-CAN totally.
I've ordered two of the aem boxes, still waiting for responce from the perfect tuning guage gentleman
Edit, email sent again. And my Canegt is from DIY. Does Jean do the firmware for these?
The Perfect Tuning gauge work by default with the original megasquirt protocol 29 bits.
But I also have the other firmware version for the gauge that I'm using for the ms2 that is working with dash broadcasting and it would work with ms3 too.
So you can change the firmware and it would work. But if you were using the 3x analog input on the gauge as an expansion box, I'm not sure if this will interfere or still work well...
I'm only using the guage to send crank case vacuum from an analog input through the gauge. I'm able to use a micro input for that now so the perfect tuning guage would only be used for displaying
