I've read through the manual but I couldn't tell if these outputs will support these features:
1. Can the PWM perform a "peak and hold" function? That is, when commanded to turn on a solenoid, the output will go high for x msec and after that go into PWM mode?
2. Can the X-axis RPM values be changed? If I need better resolution in, say, the 2500 to 3500 RPM range can I have the six values cover this range? This would be useful for a manifold tuning valve that connects two plenums on command.
3. Can the X-axis be changed to something other than RPM? This car has a hydraulic overdrive that should only be enabled (by a solenoid, the most Rube Goldberg design you can imagine) in a particular gear and with TPS in a certain range. Disengaging it also requires knowledge of the gear and TPS. My thought was to use a speed sensor that, in conjunction with RPM and clutch switch, would allow determination of gear. Can MS3 support something strange like this?
Thanks!
Generic PWM outputs - three questions
Re: Generic PWM outputs - three questions
No.Healey3000 wrote:1. Can the PWM perform a "peak and hold" function? That is, when commanded to turn on a solenoid, the output will go high for x msec and after that go into PWM mode?
Yes. Just type in the boxes.2. Can the X-axis RPM values be changed? If I need better resolution in, say, the 2500 to 3500 RPM range can I have the six values cover this range? This would be useful for a manifold tuning valve that connects two plenums on command.
No, the X-axis is fixed to RPM.3. Can the X-axis be changed to something other than RPM? This car has a hydraulic overdrive that should only be enabled (by a solenoid, the most Rube Goldberg design you can imagine) in a particular gear and with TPS in a certain range. Disengaging it also requires knowledge of the gear and TPS. My thought was to use a speed sensor that, in conjunction with RPM and clutch switch, would allow determination of gear. Can MS3 support something strange like this?
Perhaps the torque convertor lockup feature would achieve this?
Thanks James.
I think I have a work-around by using a GPIO pin to set up a condition of rpm AND MAP to determine whether to set or reset an I/O line. I would have to make a peak and hold PWM circuit to drive the solenoid, using the I/O line as an input, a relatively easy task. I assume MAP is available in the additional condition field?
The torque converter output might work for the overdrive, along with another peak and hold circuit. I may end up using a separate processor that reads RPM from the MS tach output, road speed, and TPS to handle the overdrive. If I'm making an additional pcb, may as well build all of this in.
Regards.
Regards.
