I'm running a Jeep Wrangler inline 6 engine with MS3+MS3X, it has 3 coils with built-in igniters, how to wire them to the ms3x card to run them ?
Thank you
Wiring wasted COP w MS3X
Re: Wiring wasted COP w MS3X
That sounds more like wasted spark than wasted COP. Check the manual to confirm which pins are spark A, B, & C. The order that you'll connect your coils depends on the firing order of your engine.
Yep, it's wasted spark;dontz125 wrote:That sounds more like wasted spark than wasted COP. Check the manual to confirm which pins are spark A, B, & C. The order that you'll connect your coils depends on the firing order of your engine.
My question is will i need to wire all the 6 wires "SpkA"..."SpkF" from the MS3X to the 3 coils or just 3 wires?
How to wire them properly from the MS3X?
You will be using just three spark outputs: A, B, and C
