MS3 dsm cas problem.
hi guys
i am new to Megasquirt i need some help!
i have a volvo 242gt and i have convered from k jet to ms3 ( no ms3x) still running the volvo 4cyl b23 motor.
i have built my ms3 and tested it and it is ok ( tested using jimstim.)
i initially built it to use a standard volvo hall sensor dizzy, but now am using a mitsubishi 4cyl CAS with a adapter to fit in the standard dizzy hole in the block.
the issue i am having now is i cannot get a steady rpm signal via ms3... it will sit cyling from 0 rpm-150 and if i increase the pot on the jim stim it jumps to 5000-6000 them back down randomly.
all other sensors are working correctly tps ect....
i built the 4g63 circuit (input and spark) as per the manual.... ( http://msextra.com/doc/ms2extra/MS2-Extra_4g63.htm )
i am using 4 LS1 coils and no cam input.....
can any one help or point me in the right direction in regards to what to test/ check?
Re: MS3 dsm cas problem.
4G63 requires both "crank" and "cam" signals from the CAS - otherwise it won't get RPM.
jsmcortina wrote:4G63 requires both "crank" and "cam" signals from the CAS - otherwise it won't get RPM.
the Mitsubishi cas is bolted on to a adapter so it fits on to a b23 volvo motor....... ( http://yoshifab.com/store/index.php?_a= ... oductId=45 )
i dont see how it will not work as it is just two separate signals... one crank one cam....
That's what I was saying.242gt wrote:i dont see how it will not work as it is just two separate signals... one crank one cam....
that cas has 4 cables242gt wrote:jsmcortina wrote:4G63 requires both "crank" and "cam" signals from the CAS - otherwise it won't get RPM.
1 is 12v
2 is ground
3 is "crank" signal (although it is in the cam, we consider it the crank signal)
4 is "cam" signal
here is the pinout
CKP goes to the standard crank cable in the lower harness of your ms3 (only the white wire)
CMP goes to the cam cable in the upper harness of your ms3
jsmcortina wrote:That's what I was saying.242gt wrote:i dont see how it will not work as it is just two separate signals... one crank one cam....
so your saying i cannot just run it as a crank sensor by its self? and not wire up the cam signal....?
JoseMiguel wrote:that cas has 4 cables242gt wrote:jsmcortina wrote:4G63 requires both "crank" and "cam" signals from the CAS - otherwise it won't get RPM.
1 is 12v
2 is ground
4 is "cam" signal
here is the pinout
i am only using the crank signal, wired in to the tach input on the ms relay board, cam signal is not wired in as i am only running ms3 ( not ms3x)
As I said, 4G63 ignition mode REQUIRES both signals.242gt wrote:jsmcortina wrote:That's what I was saying.242gt wrote:i dont see how it will not work as it is just two separate signals... one crank one cam....
If you want to just use the crank signal, then select and configure "Basic trigger" and use a single coil output.
Is it possible to use four LS1 coils in a wasted spark cop set up?
Do you mean wasted spark with COPs (paired COPs firing together, 2 channels for 4 coils), or wasted COP ((paired COPs firing together, 4 channels for 4 coils and a waste of pins)? Either way the answer is 'Yes'; you could also use COP ignition with each coil firing sequentially.
Regardless to use more than a single coil you must use BOTH CKP and CMP in 4G63 mode with that CAS
Support the developers!
As prof315 says, no you cannot run wasted COP without using both signals.
If you want to run wasted COP and only a single signal, then use something more accurate like a crank triggered 36-1 wheel. The 4G63 CAS is likely to be as inaccurate as a distributor trigger.
Summary - use BOTH SIGNALS or ditch the CAS.
Ahh ok thanks I am using a hi res disc in the casjsmcortina wrote:As prof315 says, no you cannot run wasted COP without using both signals.
http://yoshifab.com/store/index.php?_a= ... oductId=46
So it should be more accurate?
It should be more accurate but this also requires you to use both signals even with a single coil.
i have built the circuit as per the link above, but i cannot get a rpm signal above 150rpm... ( testing with jimstim.
and when plugged in to the car i only get 1rpm signal....
i have checked the circuit and solder joints and they are all good.
any help would be appriciated
Please take and post a composite log.
Note that with the trigger disc you are using, "4G63" is the wrong ignition mode to select. The 4G63 is for the trigger pattern, not the outside body of the CAS.
You need to use "Toothed wheel" with "Dual wheel" and configure the number of teeth etc.
See: http://msextra.com/doc/ms3/trigger-whee ... alwheelcam
Note that the manual covers this as the Nippondenso CAS as your trigger disc is not an OEM fitment.
here is my msq
That MSQ won't work. You do not have a 4G63 trigger disc.
As I said in my last post, you need to use "Toothed wheel"
ok it's been a while...
i have now purchased ms3x card
and still am having an issue,
i have set ms up as per above ( toothed wheel)
i have checked my CAS and get 5v-0 when rotated.
i have 5v pull up i have tested it with 5v pull up and without the pull up. but still no RPM signal.....
can any one shed some light on the situation...
all other sensors are working correctly... intake air, water temp tps ect...
just no rpm...
just no rpm...
Plus composite log and tooth log.
