MS3 dsm cas problem.
242gt
Re: MS3 dsm cas problem.
Post by 242gt »
i have tried to log it but there is no signal i get nothing on the tooth logger when i crank the car..
Post by jsmcortina »
Have you configured the mainboard and MS3X for your input signals?
http://www.msextra.com/doc/pdf/html/MS3 ... .3-68.html
242gt
Post by 242gt »
yes i have followed that doc,
i have set my ign settings to 4G63 and now i get 0-250-0-250-0-250rpm when cranking...
but it will not fire.....
So now post the stuff I asked for.
242gt
Post by 242gt »
242gt
Post by 242gt »
any ideas?
Post by Matt Cramer »
Please note that attachments on Turbo Bricks are only viewable with an account on that forum. Please attach the files here as well; you can use the "upload attachment" tab below the post to do this.
The tooth logger shows just the CKP signal. You will need to take a composite log as well; this will capture both the CKP and CMP signals in a single log.
242gt
Post by 242gt »
thanks for your help guys.
here is a composite log any help diagnosing this issue is greatly appreciated.
That zip contained a regular datalog. Please take and post a composite log.
See section 21 of the manual: http://www.msextra.com/doc/pdf/html/Meg ... 3-293.html
242gt
Post by 242gt »
jsmcortina wrote:That zip contained a regular datalog. Please take and post a composite log.
back at the 242 AGAIN.... still the same issue.... here is a comp log any help would be appreciated!
jsmcortina wrote:4G63 requires both "crank" and "cam" signals from the CAS - otherwise it won't get RPM.
There's still no cam signal.
242gt
Post by 242gt »
mmm ok, i have the cam signal wired to my msx3 cam input, any ideas on how to fault find it? i have had my CAS checked my a local distributor re builder here in Melbourne and it was confirmed to be in perfect working cond...
Have you posted your current MSQ? I'm not seeing it.
What trigger disc are you currently using and what does it look like? The original link doesn't have a photo.
242gt
Post by 242gt »
its a Mitsubishi cas on a distributor adapter on the b23 volvo 4cyl
As I said months ago, that MSQ WILL NOT WORK. You have set "4G63" but you do not have a 4G63 trigger disc pattern.
You need to set:
"Toothed wheel"
"Dual wheel"
24 teeth
tooth#1 angle - don't know
Main wheel speed "Cam"
Second trigger active on - Rising, or Falling.
every rotation of "Cam"
and you still need to fix your cam input signal.
242gt
Post by 242gt »
jsmcortina wrote:As I said months ago, that MSQ WILL NOT WORK. You have set "4G63" but you do not have a 4G63 trigger disc pattern.
You need to set:
"Toothed wheel"
"Dual wheel"
24 teeth
thanks for the advise i think i am heading in the right direction now thanks to you!
i have crank and cam now... i think!
will not fire now tho.... timing issue?
Have you confirmed your timing with a strobe?
I got back to my desk and checked that composite log. There's no useful cam signal there and the log shows no RPM-sync throughout.
242gt
Post by 242gt »
ahhh crap i thought i was on to a winner! d*** it......
242gt
Post by 242gt »
ok so i checked a few things and i am back to square one...
i have checked all my ls1 coild intest mode two where not working... problem fixed.. (12v supply issue)
all injectors and coils now test and working in tunerstudio testmode
i get 250-0-250-0 crank signal....... cam?? unknown..
here is my com log... and tune... does anything stand out ans wrong?
i trys to run ( kicks ect but will not idle....)
