2002 Jeep wrangler engine not starting on ms3+x
Re: 2002 Jeep wrangler engine not starting on ms3+x
You are the first person to try this wheel pattern on a six cylinder. The code needs adjusting to correct the phasing as nobody has previously been able to provide it.
Great, so I wait for it?jsmcortina wrote:You are the first person to try this wheel pattern on a six cylinder. The code needs adjusting to correct the phasing as nobody has previously been able to provide it.
My problem is that, this is a customer's car and if i tell him this he'll hang me out by my knees, hahaha
I have run my car using NGC code using MS3 but removed MS3 due to the cooling fan output not working with MS3. I never got back to reinstalling MS3 so I haven't tried the latest codes, but it worked at the time I posted my link below.
I reported the phasing issue nearly 2 years ago, It runs good if you change the phasing by rewiring. http://msextra.com/forums/viewtopic.php?f=125&t=45055 The revised phasing is in that link.
MS1extra HR11d
Neon/420 input mods
NGC code
V3 board
Dodge Neon
3.3 V6 from Caravan
5 speed
http://forums.neons.org/viewtopic.php?f=51&t=362166
Neon/420 input mods
NGC code
V3 board
Dodge Neon
3.3 V6 from Caravan
5 speed
I didn't see that post, however, it only details the phasing for wasted spark - not the full phasing for coil-on-plug or sequential fuel.
I've implemented the revised phasing and sent a test code to dochka by email. That ought to get the phasing right using the crank signal alone.
Using the cam signal and spark trim it can be confirmed if the 720 degree phasing is correct. Alter the trim on cyl#1 and see if the timing changes with a timing light. Check the "other half" (cyl#4) and make sure it doesn't change.
Yes, this should work with wasted spark so long as sequential fuel is enabled so that the cam signal is used also.
Hello James,jsmcortina wrote:I didn't see that post, however, it only details the phasing for wasted spark - not the full phasing for coil-on-plug or sequential fuel.
I've checked my mails, nothing from your end there
Please send the code to this address: Dochka_387@hotmail.com
Mail was sent on Saturday to that address. Check your spam folder?dochka wrote:I've checked my mails, nothing from your end there
Found it, will try it and report asap;jsmcortina wrote:Mail was sent on Saturday to that address. Check your spam folder?dochka wrote:I've checked my mails, nothing from your end there
By the way, you wrote "ms3 test code for v6 jeep", this is not a V6 but an Inline-6 engine :p , or maybe you mean the 1-2-3-4-5-6 firing order of the V6 by this ?
Just ignore the "V" then.dochka wrote:By the way, you wrote "ms3 test code for v6 jeep", this is not a V6 but an Inline-6 engine :p , or maybe you mean the 1-2-3-4-5-6 firing order of the V6 by this ?
Any feedback?dochka wrote:Found it, will try it and report asap;jsmcortina wrote:Mail was sent on Saturday to that address. Check your spam folder?dochka wrote:I've checked my mails, nothing from your end there
I couldn't flash the new s19 file you sent me in the zip...
There isn't any executable file or an application type file in the zip you srnt me
I never email out the loader, it is available on the Downloads page. But nomally, just save the s19 I sent over the top of the one you already have in a firmware release.
I cut and pasted the files you sent me into the ms3-release-1.3.0 file and then loaded the s19 file into the ms3;jsmcortina wrote:I never email out the loader, it is available on the Downloads page. But nomally, just save the s19 I sent over the top of the one you already have in a firmware release.
Cranked the engine and now the timing of the cyl 1 is 250 deg btdc, cyl2 is 130 and cyl 3 is 10deg btdc, means that the cyl3-4 and cyl1-6 must be switched over...
What order do you have the plug leads in?
Once the code matches the engine, spark A needs to go to cyl#1. Is this the case now?
Spark B needs to go to the next cylinder pair in sequence
Spark C needs to go to the final cylinder pair in sequence.
Spark A goes to cyl#1 but it's at 250 deg btdc not 10jsmcortina wrote:What order do you have the plug leads in?
Meaning that spark A and C fire their respective plugs, but the phasing of them is inversed, i.e the timing of cyl 1 and 3 needs to be reversed
SparkB firing cyl#2 takes place in the right engine cycle i.e 120deg btdc
Test code sent by email.
Hi James,jsmcortina wrote:Test code sent by email.
Tried this now,
Cyl 1 is correct
Cyl 2 is 250d btdc
Cyl 3 is 130d btdc
Meaning that you must switch firing order of cyl n2 and n3 so that cyl n2 is at 130dbtc at cranking and cyl n3 is at 250d btdc
The outputs run in the sequence A,B,C. That cannot be changed. Your wiring must be incorrect.
I double checked many times...jsmcortina wrote:The outputs run in the sequence A,B,C. That cannot be changed. Your wiring must be incorrect.
And how come in the test mode when i fire coil A cyl1&6 fire, coil B fires cyl2&5 and coil C fires cyl3&4 ?
Then when i crank the engine the incorrect phasing happens
Please post your current MSQ.
I have tested on the bench with Sequential fuel off or on and using wasted spark setting. The outputs absolutely 100% certainly fire in the sequence A,B,C,A,B,C with the NGC6 wheel pattern on my stim. The A,B,C match up with the spark test mode.
The composite log of my simulated signal looks very close to the composite log you posted earlier.
Any updates?
