Question Regarding 1.3.0
Just upgraded to 1.3.0 and apologize if I missed it, but where do you define spark cut X from Y?
TIA,
TIA,
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
Re: Question Regarding 1.3.0
Are you referring to the settings under Rev Limiter under Basic/Load Settings?
Brian
MS3-3X v1.3.0; TS Ultra 3.0.28; 911SC 3.0L; 3.2 intake; 2 Spartan O2 sensors; LS-2 coils; 60-2 geartooth and hall; dizzy hall
These were deleted with a hard coded setting during the prealpha stages.
Yes and in Launch Control.cmonref wrote:Are you referring to the settings under Rev Limiter under Basic/Load Settings?
I am assuming spark cut still cuts X from Y, but how did the developers determine a setting that will work for all?
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
Iirc it's a progressive random cut based on the rpm window you've specified from soft to hard
OK, so if I need to increase the limiting effect I can just widen that window? I am asking this because sometimes it gets tricky trying the limit RPMs on the 2-step with a high-hp turbo engine.
...tks
...tks
Scottie
Turbo LS Volvo 244
8.746 @ 154.94
Turbo LS Volvo 244
8.746 @ 154.94
Correct. And for me it seems to hover just under the rpm limit. For launch I'm sure I don't make as much power as you but it's effective on my setup and the revlimit has always for me and I'm close to 800whp
