is really a dumb question, i can`t find the serial conector on the ms3pro harness, and the usb drivers don`t want to work on my win xp laptop.
can anyone tell me where is the serial conector?
rs232 on ms3pro
Re: rs232 on ms3pro
I would say there isn't one, but its a DIYautotune product and this is not a DIYautotune forum. You should contact them.
Graduate of EFI University.
Re: rs232 on ms3pro
There's 2 pigtails that come from the harness. One is the USB port and the other is the square 4 pin setup that looks like a gm iac connector with a cap. That's the one your looking for.
Re: rs232 on ms3pro
thanks!!! do anyone knows the pin out of the serial conector?
on the other hand thanks about the advice of contact diy autotune.
Re: rs232 on ms3pro
Are you doing something custom? The pro should have come with an adapter cable that plugs into that 4 pin setup to a standard 9 pin setup. I use it for my Bluetooth connection
