map sensor pins?
map sensor pins?
Postby maxo-tt1 » Thu Apr 17, 2014 1:35 am
hello people, i got mapdaddy 4 bar sensor. can someone tell me whats that 6 pin? or at least wanna find ground power and signal pins.
http://www.diyautotune.com/catalog/mapd ... p-117.html
maxo-tt1
Re: map sensor pins?
Postby Matt Cramer » Thu Apr 17, 2014 5:47 am
Here you go.
Postby SDelong » Thu Apr 17, 2014 2:39 pm
Matt Cramer wrote:Here you go.
What if you would like to use the 2nd for baro correction? I assume the 3 pins labeled NC would be(from left to right as pictured) 1- 5v, 2 - Ground, 3 - Map out as well?
SDelong
Postby Matt Cramer » Fri Apr 18, 2014 6:43 am
NC means no connection.
Postby SDelong » Fri Apr 18, 2014 8:17 am
So those 3 pins literally have no purpose in any application? Mainly I am asking if the first 3 pins have any relation to the 2nd baro port and understand that NC means no connection.
SDelong
Postby Matt Cramer » Fri Apr 18, 2014 9:01 am
The 3 NC pins serve the purpose of providing mechanical support for the MapDaddy.
Postby SDelong » Fri Apr 18, 2014 9:04 am
Thanks for the clarification!
SDelong
Postby jasaircraft » Fri Dec 08, 2017 7:03 am
Hi Matt, can you post that image or something again please?
jasaircraft
Postby jsmcortina » Fri Dec 08, 2017 7:26 am
Postby jasaircraft » Sat Dec 09, 2017 7:50 pm
Thanks James
jasaircraft
Postby jasaircraft » Sun Jan 07, 2018 2:56 pm
Hi im swapping sensors on a mapdaddy 4 bar map sensor, the main sensor has gone bad (signal is permanently highest vacuum) so i swapped connections to use the other one. Why could this sensor have gone bad?
jasaircraft
Postby jsmcortina » Sun Jan 07, 2018 3:06 pm
Oil or water contamination most likely.
Return to MS3 General Support
