Page 1 of 1
map sensor pins?
Posted: Thu Apr 17, 2014 1:35 am
by maxo-tt1
hello people, i got mapdaddy 4 bar sensor. can someone tell me whats that 6 pin? or at least wanna find ground power and signal pins.
http://www.diyautotune.com/catalog/mapd ... p-117.html
Re: map sensor pins?
Posted: Thu Apr 17, 2014 5:47 am
by Matt Cramer
Here you go.
Posted: Thu Apr 17, 2014 2:39 pm
by SDelong
Matt Cramer wrote:Here you go.
What if you would like to use the 2nd for baro correction? I assume the 3 pins labeled NC would be(from left to right as pictured) 1- 5v, 2 - Ground, 3 - Map out as well?
Posted: Fri Apr 18, 2014 6:43 am
by Matt Cramer
NC means no connection.
Posted: Fri Apr 18, 2014 8:17 am
by SDelong
So those 3 pins literally have no purpose in any application? Mainly I am asking if the first 3 pins have any relation to the 2nd baro port and understand that NC means no connection.
Posted: Fri Apr 18, 2014 9:01 am
by Matt Cramer
The 3 NC pins serve the purpose of providing mechanical support for the MapDaddy.
Posted: Fri Apr 18, 2014 9:04 am
by SDelong
Thanks for the clarification!
Posted: Fri Dec 08, 2017 7:03 am
by jasaircraft
Hi Matt, can you post that image or something again please?
Posted: Fri Dec 08, 2017 7:26 am
by jsmcortina
Posted: Sat Dec 09, 2017 7:50 pm
by jasaircraft
Thanks James
Posted: Sun Jan 07, 2018 2:56 pm
by jasaircraft
Hi im swapping sensors on a mapdaddy 4 bar map sensor, the main sensor has gone bad (signal is permanently highest vacuum) so i swapped connections to use the other one. Why could this sensor have gone bad?
Posted: Sun Jan 07, 2018 3:06 pm
by jsmcortina
Oil or water contamination most likely.
