I would like to take advantage of auto shift on one of my bikes. I do not have a gear counter but would like to use the ratio option per gear. I am using my VSS or wheel speed sensor for a shaft 1 input and not VSS. I do this because it gives me quicker and better math channel for clutch slip. Can I also set the input for VSS on the same input as shaft 1 ? Or do I need two sensors ?
Thanks, Jeff
Sequential shift questions
Fastest MS powered vehicle on the planet ! 6.60@208mph
