I upgraded my ms3pro from version pre1.2 alpha 7a to the release version 1.3.1. Since upgrading the AFR2 Parameter logs a constant 0.3 to the SD data log instead of the proper AFR value. The other EGO input logs fine. My set up uses 2 WBO2 sensors and both logged fine to the SD card before the firmware upgrade. Have I missed something when uploading my MSQ to the new firmware version? Attached is my MSQ and an SD datalog.
Thanks,
Daniel.
AFR2 not logging to SD after Firmware update
26 Chev hotrod with a 1UZFE and MS3x, Flex fuel, GPIO Transmission control and LCDash.
Twin turbo LS3 powered Race boat with MS3pro and GPIO.
MS2 on a 22r in a Hilux (mates car).
MS2extra on a turbo EF Falcon (brothers car).
Toyota Supra 1jz MS2extra, COP.
13B Turbo MS2extra.
13B Turbo MS2extra.
Re: AFR2 not logging to SD after Firmware update
I've seen this reported before, something to do with the way TS handles that field in the datalog.
Go to the SDcard logging screen, take AFR2 out of the dataset and put it back in again. That ought to fix the problem.
Thanks James, I will test that later.
13B Turbo MS2extra.
13B Turbo MS2extra.
That Worked, thanks James.
13B Turbo MS2extra.
13B Turbo MS2extra.
