Setting Fixed Timing on 7mgte
3tc power
Post by 3tc power »
ok i have a 7mgte mk3 supra and the car starts on the dime and idles, I'm at the point that I'm not sure if I'm setting the timing correctly. i tried searching online but i didn't really find what i was looking for.
the above image is pretty much how my settings are, and now when i check with a strobe light my engine timing is at 8. now my question is at this point how do i adjust the degrees of the timing? do i turn my cam sensor until i get it at 10degrees or do i play with the Tooth #1 angle value?
Thanks guys!
grom_e30
Re: Setting Fixed Timing on 7mgte
Post by grom_e30 »
if its a tooth wheel setup you adjust the tooth1 angle.
3tc power
Post by 3tc power »
grom_e30 wrote:if its a tooth wheel setup you adjust the tooth1 angle.
I'm using the factory CAS 24-1
the Trigger angle/offset(deg): would this be a better option to use while trying to get the fixed timing dead on?
the image is not my actual settings...just using it for reference reasons only.
