I'm running alpha-n right now but have a Saab mad plumbed in and hope to get the setup running on maf.
I have not started tuning yet because:
Voltage reading in tuner studio withe the sensor unplugged is around 0.2v with the sensor plugged in and the engine not running I'm getting 0.95-1.05 volts. I cleaned the sensor with flux remover with no change.
Is this OK or should I toss this maf and get another?
hfm2 maf no flow voltage reading around 1v??
v2.2 box, ms2, dual wheel, sequential ignition, staged injection, boost control, maf
'87 VW scirocco, 2L16V, TD0-14T turbo, itbs
Re: hfm2 maf no flow voltage reading around 1v??
Are you sure you don't have an HFM5? The zero-flow voltage for that is 1V, less indicates reverse flow. Blow through it backwards and see what happens.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
1974 Jensen-Healey
ill try it but it looks like an hfm2 element.
Any updates? Did it measure reverse flow?
1968 Australian Morris Mini fitted with a 1310cc A+ engine
14point7 WB, TunerStudio MS Ultra & MegaLogViewer HD
My Blog: http://www.jims-blog.com
my wife just picked up a cabriolet to play with but have to swap out the motor, so my scirocco toy got kicked out of the garage for now, I haven't messed with it too much since the scirocco is running well with the itb's on alpha-n and sd with the map connected to the plenum for boost correction and control. once I get the boost control and eae dialed in, I'll have a really good base to use for comparison switching over to maf/eae.
