MS3 without MS3x external MAP
frdstang93
Post by frdstang93 »
Hello,
I am trying to figure out what I need to do to setup an external gm 3 bar MAP on a basic ms3 utilizing the on-board as a real time baro. I have looked all over the web and haven't really come up with anything. Its a 3.57 board MS3. I'm also a bit confused on what input I would use within Tunerstudios.
Thank you for your help
dontz125
Re: MS3 without MS3x external MAP
Post by dontz125 »
Take a look at the attached:
For constant baro, you need "Two independent sensors" selected; in your case, you want the "Mainboard" sensor.
Since you don't have the MS3X board, I assume you're going to want to use JS4 or JS5 as your off-board sensor inputs; you COULD use the MS3 Expansion header ADCs, but it's a little more work. Select either JS4 or JS5, as desired.
Note that you'll need to add a filter circuit for the MAP signal on a bit of protoboard.
