Location of Megaviewer cannot be found
...is the message I keep getting.
Okay, I am a computer idiot.
Loaded Tunerstudio and it works fine
Registered for Megaviewer and it's right there on my desk top and welcomes me when I click on it.
I've captured some files running the trigger and tooth loggers. I see those files and when I go to view them I am told that megaviewer cannot be found.
I would love to post some files here and I will try at the end of this rant, but not having much luck. I have datalogged on a SD card also-which I can't view. ARGH!
OMG-maybe I did it. So maybe you guys can view what I haven't be able to
Steve
1971 Datsun 240z 3.2 L6 1975 EFI intake plenum 60mmTB with 42lb Bosch injectors
MS3x 3.57 Ignition LS1 coils running full sequential
!983 Nissan 720 MS2/3.57 ported efi 26lb Bosch VW 4 tower ignition wasted spark
Re: Location of Megaviewer cannot be found
Okay-so I was able to look at my own files clicking from the forum here, but can't seem to make the direct connection from tuner studio to megaveiwer.
Attempting tooth logger next
Steve
The conventional way to open existing log files for viewing is as follows:
Open Megalogviewer
File-> Open
(go find the file you want)
Open it
View datalog.
Open Megalogviewer
File-> Open
Open it
View datalog.
The tooth log looks generally ok, possible a few damaged or rough tooth edges?
The datalogs are short and don't appear to show anything of interest. The engine is running.
Thanks James
Steve
Steve,
Nothing to do with your op. but did notice that you are idling at ~30% throttle....... Is the tps not hooked up?
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
No TPS
Steve
In that case, connect the TPS signal wire to "sensor ground/return" to avoid it floating.Madkaw wrote:No TPS
Does that effect my tune in anyway ? Just running ignition.
Steve
