can I take timing away based on water coolant temps??
stock fox 5.0 mustang ECUs do this. stock ecu pulls 2 deg between 60-100%load & 4 deg at 230 deg 40-100% loads
I would like to start pulling some timing when coolant temp reaches 195deg...
turbo mustang
thanks
lower timing based on coolant temp?
Re: lower timing based on coolant temp?
Yes, and it can also do it based on IAT. (What MS do you have? That may not be true on an older version)
billr wrote:Yes, and it can also do it based on IAT. (What MS do you have? That may not be true on an older version)
ms3/ms3x (latest firmware) where do I find this in tunerstudios?? I found air temp / timing not coolant based
thanks!
Joe
This would be done by putting negative values in the Cold Advance table.
