sync problem
sync problem
hi guys having a problem with a car for some reason looks like the crank signal disappear after the car cranks for a couple sec im using a 36-1 wheel on the crank and 1 on the cam im using a cherry hall sensor I try adjusting r56 pot but no luck at all any input its really appreciated.thanks
Re: sync problem
Can you run the composite log until the loss of sync problem pops up (it was still synced fine at the end of that log), and also post your MSQ?
Re: sync problem
sorry for the delay was out on the weekend heres another composite log and a thooth log
Last edited by elturbonitroso on Tue Jul 22, 2014 3:20 pm, edited 1 time in total.
Re: sync problem
The composite log was not synced at the very beginning, but I couldn't tell what caused it to lose sync. Can you post a composite log that shows it going from correctly synced to the signal disappearing?elturbonitroso wrote:sorry for the delay was out on the weekend heres another composite log and a thooth log
Re: sync problem
ok guys have a ? does the cam trigger needs to be on the exhaust or intake cam or that does not matter?
Re: sync problem
It wouldn't matter as long as it occurs in the correct spot relative to the crank wheel and tooth #1 angle.
Graduate of EFI University.
Re: sync problem
I think I found 2 problem 1st one I put a pullup on the looms of my cherrys sensor and built my ms tach input for vr+pullup for hall at the same time and I think that I should take the pullup out of the tach inputs on my ms. and 2nd my cam indicator its right at tdc with my #1 tooth.
Re: sync problem
That looks like what you should be seeing. No loss of sync or signal in that picture.
Re: sync problem
well I rearrange my cam sensor and the car start the only think its that sometimes when I try to start the car Im getting a check engine ,sync fault but the car start idle perfect.
