sync problem
elturbonitroso
sync problem
Post by elturbonitroso »
hi guys having a problem with a car for some reason looks like the crank signal disappear after the car cranks for a couple sec im using a 36-1 wheel on the crank and 1 on the cam im using a cherry hall sensor I try adjusting r56 pot but no luck at all any input its really appreciated.thanks
Re: sync problem
Post by Matt Cramer »
Can you run the composite log until the loss of sync problem pops up (it was still synced fine at the end of that log), and also post your MSQ?
elturbonitroso
Re: sync problem
sorry for the delay was out on the weekend heres another composite log and a thooth log
Last edited by elturbonitroso on Tue Jul 22, 2014 3:20 pm, edited 1 time in total.
elturbonitroso
Re: sync problem
here are some pics too they are not the best but any input its really appreciated.
Re: sync problem
elturbonitroso wrote:sorry for the delay was out on the weekend heres another composite log and a thooth log
The composite log was not synced at the very beginning, but I couldn't tell what caused it to lose sync. Can you post a composite log that shows it going from correctly synced to the signal disappearing?
elturbonitroso
Re: sync problem
ok guys have a ? does the cam trigger needs to be on the exhaust or intake cam or that does not matter?
elutionsdesign
Re: sync problem
Post by elutionsdesign »
It wouldn't matter as long as it occurs in the correct spot relative to the crank wheel and tooth #1 angle.
Graduate of EFI University.
elturbonitroso
Re: sync problem
I think I found 2 problem 1st one I put a pullup on the looms of my cherrys sensor and built my ms tach input for vr+pullup for hall at the same time and I think that I should take the pullup out of the tach inputs on my ms. and 2nd my cam indicator its right at tdc with my #1 tooth.
elturbonitroso
Re: sync problem
heres a better pic of what happen on the composite logger
Re: sync problem
That looks like what you should be seeing. No loss of sync or signal in that picture.
elturbonitroso
Re: sync problem
well I rearrange my cam sensor and the car start :yeah!: the only think its that sometimes when I try to start the car Im getting a check engine ,sync fault but the car start idle perfect.
