2 problems Trigger weel and bluetooth
Hi, I have a problem.
1.How to set the wheel when the eighth tooth is on the sensor and A first piston is at the top in the sequence
in TS i have Tooth # 1 Angle BTDC in 80*
at which the tooth should be a second sensor?
when i have 70* car drives better :/
2. where do I connect the bluetooth HC 05 module ( tx and rx)
engine is 3.0 24v w124 r6
Re: 2 problems Trigger weel and bluetooth
all the info is here http://www.msextra.com/doc/ms3/trigger-wheel.html re the trigger wheel
and some info on the bt http://www.msextra.com/forums/viewtopic ... 22&t=43883
Thanks for your help. About Bluetooth to reading, about the wheel but I'm not able to understand. I need the specific help
it should be set to the other wheel if I first eighth tooth BTDC and settings in TS
give full details on you trigger wheel set up eg 36-1 and a single tooth on the cam what tooth lines up with the sensor when the engine is set at tdc on cylinder 1.
When cylinder 1 is set at tdc
Trigger weel 36-1 is the eighth tooth in the VR sensor
when the second sensor is the metal (cam) trigger weel have second tooth
http://zapodaj.net/5fb59324fa53d.jpg.html
http://zapodaj.net/4ee18a978bf0a.jpg.html
http://zapodaj.net/c0defa2413933.jpg.html
and I have one question, is it true that it is better to have the ignition sequence in half?
Have you checked your timing with a strobe timing light?
http://www.msextra.com/doc/ms3/checktiming.html
No, I did not check Ihave a set from a friend, which have this same engine COP .... But He have VR sensor in trigger weel at nine (9) tooth .
I do not have access to Stroboscopic timing light
You need to get one.Booster wrote:I do not have access to Stroboscopic timing light
Otherwise, maybe you prefer to replace melted pistons?
