Connecting to MS3X
Connecting to MS3X
MS3X powered on, connected laptop via serial port.
Serial port in BIOS activated.
Tuner Studios installed on computer.
Run TS new project. TS can not find a connection.
Run Port Check, 2 valid ports found.
Com2 Opened
115200 baud
No connection made.
9600 baud
No connection made.
Same return on com3
Searched forum, can not find an answer.
What is my next option to connect MS3X to computer.
Com2 Opened
115200 baud
No connection made.
9600 baud
No connection made.
Same return on com3
Re: Connecting to MS3X
Have you gone through the serial loopback tests etc. that are in the serial setup page in the manual?
Yes, I downloaded CDM 20814 setup.
That's when I got com 2 and 3.
Will not connect through TS using a new car project.
Earlier using the mini terminal in TS I got a return echo on com 3 now itis not working.
Is CDM 20814 a serial usb converter?
The test is shown here:
http://www.msextra.com/doc/ms3/serial_setup.html
http://web.aanet.com.au/arran
Yes, CDM 20814 is the serial USB converter. I installed from the link.arran wrote:Is CDM 20814 a serial usb converter?
MS3X is connected to computer with power on.
Run test find
Com4 Opened
115200 baud
No connection made
9600 baud
No connection made
1 valid port found
What is the actual COM port of the USB-serial ? The manual page shows how to find it through Device Manager.
com port3 is set in device manager
The Receive Buffer and the Transmit Buffer sliders are set to low.
MS3X is connected to Laptop, power is on
Serial connection comport 3 is selected
USB A-B cable com 4 is selected
Run port check returns
com 3 or 4 opened
115200 baud
no connection made
9600 baud
no connection made.
valid port found.
com 3 or 4 opened
115200 baud
no connection made
9600 baud
no connection made.
valid port found.
Made some progress.
Uninstalled TS, shut down and restarted computer, installed TS from online down load.
Port check opened com3.
The mini terminal in TS returns an echo.
Connecting through ms3loader_win32.exe
No connection is made.
Connecting through TS new car project.
One more thing port check is connecting through com3.
Device Manager is set at com4. When device Manager is set to Com3
no connection is made.
Anyone what is my next move.
Do the responses change if you power up the MS3 with the boot jumper in place?
I am trying to connect with MS3X.
Using the USB A-B cord.
This sounds like the issues I was having when I didn't have the ftdi drivers installed.... I could see the port but it would not comm with the MS3, would not loadfirmware...
Yes, FTDI Drivers are installed, See post #5S.Bretz wrote:This sounds like the issues I was having when I didn't have the ftdi drivers installed.... I could see the port but it would not comm with the MS3, would not loadfirmware...
laptop connected to ECM with USB A-B cable.
The driver opened the com port
The Port Check 2.1
opened com 3
mini terminal in TS
echos back
The ms3loader_win32.exe can not find an open port or connected ECM
Start a new car project in TS can not find the ECM
AH...gotcha, its been a long time since I installed that. I didn't realize it came up with CDMxxxx
Is it possible to borrow another computer to rule out the computer being stupid?
I will load it on my desk top see what happens.
Would sure like to have MS installed on the lap top for on the road tuning later on.
Loaded MS on the desk top.
Connected with USB A-B
Port Checker found and opened com5
TS mini terminal did not echo
ms3loader_win32.exe did not connect.
Does the desktop have a DB9 serial port? If so, try it.
The desk top does not have a DB9 connector.
This is most odd - "portcheck" and the loader are almost the same code as far as serial comms are concerned.Ollie8974 wrote:Port Checker found and opened com5
Please run the loader again and use debug option #3, this will spew out lots of serial debugging information.
Please upload a screenshot of what it says during probing.
Screen shot of ms3loader_win32.exe
