Can someone with a known good VND5N07 post your multimeter test results ? I found some post about bad ones and what they measure just nothing on what they should measure.
I have a Triplett 9005-A and it seems I cant close the gates, I am leaning towards my meter not putting enough voltage out to close the gates.
Thank you
-Kemp
MS3x injector driver test
Re: MS3x injector driver test
Here is what I see while testing in Diode test mode
-on input / + on source = 610
- on drain / + on source = 548
I get no other resistance in any other combination , I do have the ribbons removed from the MS3x .
-Kemp
-Kemp
