Plx dm-6 and ms3x gauges reads .2 different
3tc power
Post by 3tc power »
ok so i did a search before i made this thread because i don't want to make something that is already floating around. ok so i got my mk3 supra running full sequential ign and fuel. not i noticed my ms3 AFR gauge was reading .2 leaner than my PLX gauge. they pretty much move together but like i mentioned ms3 is .2 leaner for some reason. and another thing i noticed is that my car seem to like idling 13.0 better than 14.0-14.7 afr which is weird to me since I'm full sequential.
thanks in advance
Re: Plx dm-6 and ms3x gauges reads .2 different
Post by Matt Cramer »
Where is the wideband grounded?
3tc power
Post by 3tc power »
Matt Cramer wrote:Where is the wideband grounded?
i grounded it to the Chassis under the dash!
What happens if you relocate that to a point approximately 1-2" from the MegaSquirt ground location?
Precision electronics require precision grounding.
3tc power
Post by 3tc power »
Matt Cramer wrote:What happens if you relocate that to a point approximately 1-2" from the MegaSquirt ground location?
so i have to use the same ground as the ms3 for them to be on the same page? or close to the same point as the ms3?
Exactly.
3tc power
Post by 3tc power »
ok cool thanks for the help Matt Cramer! i will post my results when i move everything.
3tc power
Post by 3tc power »
So i found out what my idle issue was. it turns out that the old delphi 880cc doesn't like to idle around 13.8-14.7 afr, seems like everyone that has them had the same issue.(they like rich idles)
but i moved my ground of the PLX DM-6 to the same ground as the ms3 but is looks like it got worse than where i had it before. on my afr calibration settings i noticed that if i select a specific calibration burn it go out and go back in the calibration settings it won't show what i had selected before. is that normal?
kjones6039
Post by kjones6039 »
Yes.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
3tc power
Post by 3tc power »
ok thanks kjones6039
well i moved the ground directly to the head and it seems to like it better there. not perfect but i will live with .2 difference. not moving that s*** again lmao, but thanks for the info guys i really appreciate it.
